I wish I could afford HD... - Page 3 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > Area 51
Area 51
We can neither confirm nor deny its existence.
Old April 18th, 2006, 02:04 AM   #31
I googled a price on it a while ago (or emailed) on it, not cheap, I think that it was over a thousand or thousands.
Wayne Morellini is offline   Reply With Quote
Old April 18th, 2006, 06:06 AM   #32
Capt. Quirk
That's still way cheaper than a deck that can't capture 4:2:2, and even more so than a Mac or Wafian. More portable too!
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old April 19th, 2006, 06:12 AM   #33
One of the guys here is doing a commercial HDSDI uncompressed recorded for around $2.5K (Likely to be expanded to to other formats). There is stuff coming that has pretty good compression before end of the year, but I am under confidentiality. But you might the one from Earthsoft, it is similar in capability as DVCPROHD, it is cheaper, but I don't know if the codec is truly compatible with work flow.
HDU-1 HDSDI:
http://www.dvinfo.net/conf/showthrea...498#post459498
Earthsoft:
http://www.dvinfo.net/conf/showthread.php?t=61344
Old April 27th, 2006, 11:08 AM   #34
Originally Posted by J. Stephen McDonald
Two things about that: First, there are many HD monitors of all sorts that are promoted as being 1080-capable, but can't really resolve that many lines. This is just a continuation of the marketing tactics that have been used to push wide-screen TV sets for the last dozen years. It's not an issue you will likely see discussed on any type of TV news program.
A matter of coincidence, this is similar to what you are talking about, it is about:
http://www.theinquirer.net/?article=31270
Wayne ;)
  You are here: DV Info Net > And Now, For Something Completely Different... > Area 51
