High Definition with Elphel model 333 camera - Page 9 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
Old May 7th, 2006, 03:51 PM   #121
Andrey,
I have some good news, that I will be posting sometime over in my digital cinema technical thread.
I have reviewed the sensor information and things have changed quiet a bit. Kodak is supposed to have some 100K -ev well sensor chip, so I am interested in those Kodak options you mentioned.
Micron has got superwideVGA chip with multislope, so I am interested if any of their chips that you use in future have this excellent feature.
But the biggie, apart from some behinds the scenes doc I have on a new sensor people have been eagerly waiting for for years that is quiet an excellent choice for you (though not in price). Is that I have found a cheap Russian, alternative to the x3 Foveon. I will email you privately as I want some space to negotiate with them first, without non business/electronics professional people rushing them for information.
Wayne.
Wayne Morellini is offline
Old May 10th, 2006, 01:30 AM   #122
Originally Posted by Wayne Morellini
Andrey,
Wayne,
sorry for late reply - I'm just back from the linuxtag.org. I really appreciate information on the new sensors but I can not work with them myself (at least in near future) - there are so many current projects. So right now I can just provide some help to somebody who can work on them.
Andrey
Andrey Filippov is offline
Old May 10th, 2006, 01:50 AM   #123
Funny you dismissed me like more than a year ago when I asked you about using your camera for High Definition stuff.
Now I see you here....
Juan M. M. Fiebelkorn is offline
Old May 11th, 2006, 04:48 PM   #124
It is not my speciality :-) , and this application of our cameras is community-driven.
Old May 11th, 2006, 05:50 PM   #125
Originally Posted by Andrey Filippov
Wayne,
Andrey
That's OK, but I know that you work with micron and mentioned Kodaks. Do any of the Microns that you are using, are planing to, use the dual/multislope. You were talking about the Kodak, are you planning on using the 100K -ev ones, or the 65K -ev ones?
Wayne.
Old May 24th, 2006, 09:09 AM   #126
333
Originally Posted by Oscar Spier
Forrest (and others)
I got my camera a few days ago. I'm not able to do tests this week because I'm out of the country, but I'll follow this thread and post my results when I'm back.
Oscar,
Any luck using this camera???
Donnie Wagner is offline
Old May 24th, 2006, 10:30 AM   #127
I'm sorry it took so long.... I had a lot of trouble finding a way to capture the footage. I now have figured out a stupid work around, so that's OK for now.
I had luck finding a very (as far as I can tell from my first tests) good C - mount lens on an 'antique' 16mm film camera. here are some tests shots I made with the camera and the lens:
http://bosshogg.logjam.com/oscar/Elphel/rez.jpeg
http://bosshogg.logjam.com/oscar/Elphel/rose.jpg
http://bosshogg.logjam.com/oscar/Elphel/rose1.jpg
http://bosshogg.logjam.com/oscar/Elp...-artifact).jpg
Two of the shots with the rose (shot through a dirty window) are toughed up in AE. One of them 'rose(de-artifact) ' has some enhancements (de-artifact and 0,5 box-blur) to reduce the compression distortions of the Elphel camera.
One of the big problems I still have is the rolling shutter effect on quick moves.
I'm also working on the wax adapter.
Oscar Spierenburg is offline
Old May 24th, 2006, 11:03 AM   #128
do a green screen test to see how the color compression is
Riley Harmon is offline
Old May 24th, 2006, 02:26 PM   #129
Oscar, those rose grabs where at about 1700 by 800. what fps where you able to capture that at? or where they more for still test purposes.
Forrest Schultz is offline
Old May 24th, 2006, 03:55 PM   #130
No, it's a real frame-grab from a clip I shot at 24 fps (1728 x 896)
I'm very glad and surprised that my 1.5 GHZ Intel celeron (!) laptop can capture at that resolution. When I make a battery pack of some sort for the camera I'm very mobile already...only one cable between the laptop and the camera.
How are you doing with you Elphel Forrest?
Old May 24th, 2006, 10:28 PM   #131
Theres no surprise, you are getting from 30-70mbs (from what I seem to understand) which is upto around 9MBytes second, next to nothing and a number of drives can handle that now days.
Old May 25th, 2006, 02:55 PM   #132
Forrest or Oscar,
Have you tried playing with higher frame rates for slow motion shots? 640 X360 would be like letterboxed standard def, and you could get framerates up to probably over 100fps. It may not look very good at that low resolution, Then again, until the recent HD cams, SD was just fine. In conjuction with a 35mm adapter to make the subject pop, you'll be able to do some really cool slow motion.
Also, does the camera do windowing or sub-sampling for lower res?
Overall I really like this experiment that Forrest and Oscar are trying, the heavy compression keeps it from being a real professional camera, but it's affordable, has a manageable data rate, and can do real slow motion (I hope).
There should be a whole host of new Gig-E and firewire B standard industrial cameras coming out soon that will be the subject of much experimentation, which is great.
Thanks guys, neat thread here...
Old May 25th, 2006, 10:20 PM   #133
Which new cameras are those? You know there are already thousands of industrial cameras.
Old May 26th, 2006, 08:15 AM   #134
I said "should" and "whole host"
not "know" and "thousands".
Rob at Graftek (http://www.graftek.com) discussed it with me. He said that "when new faster connectivity standards come out so do new devices that can take take advantage of the extra bandwidth; ; so expect a whole host of new industrial cameras in a few months." Made sense to me, so I thought I'd voice my enthusiasm.
Old May 26th, 2006, 08:17 AM   #135
Industrial Cameras
double post, oops
  You are here: DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
