#1081 |
Batteries voltage drop might be influenced by the current drawn from the cell at the time of measurement so I am afraid I do not have enough knowledge about this to build a safe battery pack.
But I think this monitoring device (Arduino or any other microcontroller) should be integrated in the battery pack. Otherwise it could result in the battery pack catching fire and destroying the camera or worse if the operator selected the wrong battery type and only the camera is monitoring the cells. As far as I know the next camera CPU will be based on a very similar chip to the beagleboard: A Texas Instruments Davinci .... ARM CPU with video coprocessor. |
#1082 |
Sebastian/Philippe,
Alexandre mailed me an interesting link to an Arduino alternative (and possibly better): Teensy USB Development Board (teensy++) What do you think? Anyone here has experience with this? Oscar |
#1083 |
Teensy looks great:
-) smaller than Arduino -) more IO pins than Arduino, better specs -) Development Environment seems to be compatible with Arduino -) cheaper than Arduino Only con I see so far: -) Cable on Mini USB jack detaches easier than the normal sized USB jack in the field Small update on the Dictator: -) I totally forgot 2 things: the Rec button and the on/off switch :) Since the Teensy++ has 46 IO pins we could easily add more pushbuttons (they are very cheap as well). What other settings would you like to be able to change with a pushbutton? Here are some images of the available pushbuttons of the competitors: http://www.dvuser.co.uk/images/img/n...-back-1920.jpg http://www.vanbrandwijk.eu/uploads/image/ex3.jpg http://www.panavision.co.nz/images/_large/aghvx200.jpg http://www.digitalcamcordernews.com/...-hvr-s270u.jpg http://www.hd-tv.nl/images/news/282.jpg |
#1084 |
Looks good. Would this be possible to build in some kind of project box (with pre-made holes for knobs, LCD and buttons)? This way you could make a DIY guide for people who want to make it themselves and we don;t need custom manufacturing. I'm searching, but didn't find anything yet.
EDIT: Maybe we could look for things like this: Product Photos Product Photos Here is a cheap battery+charger I came across: Laptop Nimh Universal External Battery, 12V 3500mAh + Wall Charger for IBM Sony NEC etc (P1000) - CH-1540-UNC03 Last edited by Oscar Spierenburg; April 21st, 2009 at 01:33 PM. |
#1085 |
Very interesting link!
I found a very interesting company that makes custom designed front panels (with there own software) . So a simple project box and a custom front panel would make a perfect Dictator enclosure.
I did a quick test with the software (using Sebastian's design as reference): A black aluminum panel (100x60mm) would be $ 18.- (10% discount at 10 items, 20% for 20 etc.) Home*- Front Panel Express, LLC > Front Panel Service for North America |
#1086 |
Very cool!
For prototyping any CNC mill should be able to do the job. But 18$ looks like a very good offer (does it even incude printing/engraving on the panel) and the company you found could in general be very interesting for our needs. |
#1087 |
very cool oscar the link
here is a link to an arm for the tablet or lcd that is strong and good looking Holding System By NOGA pdf sheet Very useful the dictator concept I've not understand what does the two rotary encoders or better, does we need 2 rotary and a 2axis joystic? maybe with the next revision of the elphel we have some more processor power to do video output so a simple LCD + dictator could do the job Last edited by Matteo Pozzi; April 22nd, 2009 at 03:08 AM. Reason: added info |
#1088 |
Interesting product Matteo.
Does anyone know if a 6mm c-mount intended for 2/3" sensors has the same FOV as a 6mm c-mount lens intended for a 1/3" sensor? I mean: is it calculated for c-mount in general or for the sensor size? Or is it just that you can't fill the whole 2/3" sensor area with a lens that was intended for a 1/3" sensor? If not, what is the multiplier factor? |
#1089 |
Oscar,
I read (forgot where) that it depends on the lens. Some have enough coverage for bigger sensors, some don't... It seems you have to test. Well, if you order online, it's another problem :-/ |
#1090 |
exaclty as a aps-c for actual reflex and a 35mm lens
as you said Oscar "you can't fill the whole 2/3" sensor area with a lens that was intended for a 1/3" sensor" take care that some industrial lens are for example 3mega pixel capable but only for the sensor size they are designed for a 3mpix camera for 2/3" can resolve about 1mpix on a 1/3" sensor for size and some info about thake that link Optical Characteristics of Video Lenses and look at the tamron catalog for c-mount lens Tamron CCTV and Photographic Lenses for Factory Automation, Machine Vision & Security they have monofocal lens that have a minimum object distance of about 10cm (like fujinon one but fuji is more expansive) so we can use adapter without achromat lens to reduce that distance |
#1091 | |
CNC milled/drilled front panel
PIXEL PARTNER (R) Thomas Kumlehn Last edited by Thomas Kumlehn; April 28th, 2009 at 05:11 AM. Reason: added kits |
#1092 |
Ready-made part list
Hi everyone.
I'm working on the rods support design again. How about collecting all ideas for ready-made (existing) parts? By this I mean: hand-grips, rods, microphone holders, knobs, electric wiring solutions etc.. There should be numerous cheap parts around to make almost the whole Rods support and mount all accessories. Lets first bring together ideas and put it in an open google-document later on. So far I noted: hand-grip: AF10926 Barska Accu-Grip Handheld Binocular Support System, Pistol Grip with 1/4-20 Male Thread, Black Plastic. universal holding arm(Matteo): Holding System By NOGA Ready to use battery system(Polto): DigiPower The first thing I'm looking for for the design is a universal laptop or monitor holder. One that should be adjustable to hold any small type of laptop/tabletPC/7"monitor. Something that fits this design Image:Perspective2.jpg - ElphelWiki .. so it doesn't need to have an arm. All ideas are welcome! |
#1093 |
Slightly updated Dictator concept.
The whole interface can be locked with a sliding switch and 2 sliding switches can lock each rotary encoder individually. About the parts: How does this NOGA arm system compare to a traditional magic arm? Price, weight, ease of use, .... The Handgrip looks good and cheap. For later revisions we might think about our own design with some buttons to start/stop recording for example. |
#1094 |
About NOGA arm:
HoldIT - DG Holder 3/8" - 1/4" +Nut. - DG11043 I've contacted an italian distributor (by phone) and they told me that the price for the DG11043 is 80euro (support for 4kg) and for MG11043 is 95 euro (support for 8kg) but these are for cinematography purpose I think that the same result could be achieved with the arms in the first noga link I've post that, as distributoris said, are cheaper. |
#1095 |
We should also be looking for something like this: RAM-234-6 Tough Tray II because the NOGA arm can not mount a laptop or tablet PC.
This is the only laptop "clamp" I could find. Does anyone know of other/cheaper ones? |
