#451 | |
#452 |
thanks for the detailed expenation :)
#453 | |
many thanks Matteo |
#454 |
Yes!
..I second that! :)
Thanks!! //O. |
#455 |
Images are really ugly (so I do not want to post camera IP here :-) ) - the only sensor 5MPix board left I had has a malfunctioning sensor (probably not all he sensor chip pins were hand-soldered nicely) and I did not yet finish porting of all the software (some parts are still missing - like setting the gamma tables).
My goal was to test hardware before going to larger batch, especially interface to the new CPU - PIO, interrupts, DMA. I even had to solve some problems with the new Spartan 3E (vs. Spartan 3) FPGAs to make them work as needed. So this part works and being built as they are tested so far 10353 can do at least what 333 could. There are some features not tested yet (IDE, USB, fast system bus acquisition) - but that will be done later - in parallel with the camera manufacturing. |
#456 |
PHP in 353
I hope it can make development of the camera interface easier - PHP now works in the 353
#457 |
cool I tink is possible to use it to make a database to save the setting
and to load preset ....did you suggest some more spec that can be used with this new capability (php rocks)? |
#458 | |
#459 |
Php...
Andrey,
PHP in-camera - very cool... ..would it be possible to start a in-camera timer that executes a PHP script say every 5minutes or something...taking a photo or doing something else? Just curious //O. |
#460 |
I believe there are some light Linux distros which can be installed and run from a USB memory stick. Compared to running the OS from a live CD, this would be a way to save camera settings. I imagine though there are a number of reasons why this is not suitable for the job in hand...
#461 |
Yes, we have one on a 4GB USB stick. The problem is - not all the computers yet boot from the USB stick.
#462 |
Andrey, how did you install the knoppix to the USB stick?
#463 |
Hi Andrey have you seen that in april will be released the new version of ubuntu (Feisty Fawn project) and also in the same period april will be relesed ubuntu studio http://ubuntustudio.org/
" Ubuntu Studio. A multimedia creation derivative of Ubuntu. Ubuntu Studio is aimed at the linux audio, video and graphic enthusiast as well as professional." maybe we can start make a new version of the live cd starting from this distro ....it is more motion picure oriented! |
#464 | |
#465 | |
