High Definition with Elphel model 333 camera - Page 27 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
Old January 30th, 2007, 09:27 AM   #391
I've asked Andrey if he has some time to clear some things up over here...
If it's 'plain' HTML language, I can possibly help myself.
Oscar Spierenburg is offline
Old January 30th, 2007, 10:03 AM   #392
Interfacing the 333, 353 status
I recommend using ccam.cgi, as we do not have anybody to support Video API now - the FPGA/drivers code went ahead and Video API is lagging.
The latest production firmware is 6.4.35 (available at SourceForge), default streamer (working) is made by Khlutchin, you may try it with the computer boot from our Live CD/DVD were the Mozilla plugin to view RTP stream with MPlayer is already configured.
With MS Windows you may try the software - it should probably work with the same firmware 6.4.35.
https://sourceforge.net/project/show...kage_id=217626
Meanwhile I'm busy with the 353 - I had to change the design to use "large page" flash as the ones I used became obsolete in several months after they appeared. a good thing - the new flash is twice bigger (128MB).
Now I'm testing the second revision of the 353 board - hope to get real images from it next week.
I also released multiple other boards that will work in/with the 353 camera - these boards will be tested in the next couple months:
10357 - a board with 8 CF slots - with 16GB cards it will be possible to have 128GB solid state "disk";
10359 - splitter/preprocessor for up to 3 sensor boards. It has the same FPGA+DDR SDRAM as the main board and should be capable of some image pre-processing (like some of 3-d extraction from stereo imagers). I plan it to make an optical camera position tracker to compensate for the ERS distortion effect. This board is connected to the 10353 board instead of a single sensor board and has 3 of the same flex cable connectors fro connecting up to 3 sensor boards to it.
Next 3 boards are designed for non-video applications (2 fps, 11 and 16 MPix with Kodak KAI-011002 and KAI-16000 CCDs) - improved from our model 323 camera:
10347 - Timing/control for KAI series sensors;
10342 - KAI-11002 sensor front end - in pair (sandwich) with 10347 allows connection of KAI-11002 to 10353 board;
10344 - same for the KAI-16000 sensor.
Andrey Filippov is offline
Old January 30th, 2007, 11:23 AM   #393
Andrey,
Can you make support for Kodak KAI-2093. This would be very interesting for us! If you can make this how much would cost 353 with this sensor? Anyway have you ever seen footage from this sensor? Is this any good for us (film making )?
I have also have interest for 353&KAI-11002, how much will be cost estimate for this combo?
Igor Babic is offline
Old January 30th, 2007, 01:46 PM   #394
But can we change the ccam.cgi and save it in some way.
If you look at the page of one of the online cameras as a HTML source, you see a very complex script, but still, it's a html webpage. Can it be edited and saved to the camera or LiveCD?
Old January 30th, 2007, 07:39 PM   #395
Oscar,
you can change ccam.cgi but you do not need to do it. It is a binary application that processes HTTP requests in the camera, requests themselves are generated from html+javascript (camvc.html, *.js) files in ftp://<camera_ip>/usr/html/ directory (visible as http://<camera_ip>). This directory resides in JFFS system and is write enabled so you may change/add files there. For experimenting I would recommend using /var/html directory (linked as /usr/html/var) that is in RAM-disk so it is perfectly safe to change data there (will be erased after reboot) - files will be visible as http://<camera_ip>/var/
Andrey
Old January 30th, 2007, 07:43 PM   #396
Originally Posted by Igor Babic
Andrey,
Igor, maybe it is possible, but I can not work on this right now. I can help if somebody will be eager to do that - it is likely that the 10347 will work as is, just 10342 should be replaced by a sensor-specific one.
I have the design files for the not-yet-released boards in the password-protected directory, but we do give access upon request.
As for the price - these cameras are more expensive, especially the senors themselves. I can estimate it may be 50% more than the 333 camera, plus the cost of the sensor.
Old January 31st, 2007, 08:08 AM   #397
Many thanks Andrey so if we make an html page with buttons that link to a HTTP requests in the camera we can make a different GUI right? ok, you say that is better use ccam.cgi so the http request of the button of the new gui will have to "start" with http://<camera-ip-address>/admin-bin/ccam.cgi? + the parameter that they change like described in http://wiki.elphel.com/index.php?tit...2C_XML_or_VRML
or can we use also the link described in http://wiki.elphel.com/index.php?title=Video_API
How much, big (kb) will have to be the html page? is it possible to use .swf flash file to save space and make a better graphics? I've seen F4L (http://f4l.sourceforge.net/?q=node&from=30) and maybe.....
and last did you plan to produce a 5 mpixel camera based on 333 hardwere?
Matteo Pozzi is offline
Old January 31st, 2007, 09:57 AM   #398
Yes, that is correct
This API is lagging behind ccam.cgi ( - we do not have anybody to work on it now. As for ccam.cgi - I always upgrade it myself when I change drivers or FPGA code. So it may be ugly (being incrementally patched from our first model 303 camera), but it is current.
Actually - a lot. in the 333 it is probably around 8MB (flash is 16MB vs. 8MB in model 313 and the amount of software is not much higher). In 353 flash is 128MB.
and last did you plan to produce a 5 mpixel camera based on 333 hardware?
Yes, the 5MPix board was designed for 333 (and is supported by the current firmware). The only difference between 5MPix sensor board (10338) for 333 and 353 is the interface voltage and a single linear regulator IC on the board determines that.
Old January 31st, 2007, 12:19 PM   #399
Thanks Andrey, very good info, you are most helpfull.
So for KAI-2093 we are talking about under 3000$?
Is it GigE in your plans for 353 or any other model?
I think that you mentioned IDE interface before CF? Whats happend?
I like interchangeable CF idea but I like more fixed IDE.
Keep up your good work.
Old February 1st, 2007, 09:35 AM   #400
I'm also interested in a camera using the KAI-2093 or KAI-4021 sensor.
Solomon Chase is offline
Old February 1st, 2007, 11:17 AM   #401
I don't know the price of KAI-2093, but probably you are right.
No, will stay with 100 for a while - it is supported in the CPU itself. I'm counting on better compression.
The main 10353 board has IDE signals on a high-density 40-pin connector that will need just an adapter to connect HD. 10357 board connects to that IDE and has a programmable FPGA that initially will work as a simple multiplexor switching that bus to one-of-four , each having 2 (master/slave) CF cards connected (used in "true IDE" mode).
Of course you do not have to use that board and just connect a HD instead.
Old February 1st, 2007, 01:26 PM   #402
If we change the software html layout, is there a way to link the record button to a simple sound recording? Possibly with the output in the same directory as the video file?
Old February 1st, 2007, 11:37 PM   #403
Any additional board to get a PCI connection to the main board?
Juan M. M. Fiebelkorn is offline
Old February 2nd, 2007, 02:43 AM   #404
Hi Andrey so when will be abvailable the 333 + 5mpixel cmos micron sensor?! it will be the MT9P001I12STC sensor unit? how mutch will cost? but it will be better then the 3.1mpixel MT9M001 one? comparing the specifications of these units on micron's site you can find:
------------------- MT9P001 5mp ------------- MT9M001 3.1mp
Resolution: ______ 2,592H x 1,944V __________ 2,048H x 1,536V
RoHS: _______________ Yes _____________________ Yes
Pixel Size: ________ 2.2µm x 2.2µm ___________ 3.2µm x 3.2µm
Mega Pixel: _________ 5Mpixel ___________________ 3Mpixel
Optical Format: ____ 1/2.5 inch _________________ 1/2 inch
Frame Rate: ________ 12 fps ___________________ 12-93 fps
Master Clock: ______ 96 MHz ____________________ 48 MHz
Supply Voltage: ___ 1.7V-3.3V ___________________ +3.3V
Output: _________ 12-bit parallel _____________ 10-bit parallel
Shutter: ____________ ERS ______________________ ERS
Package: ___________ iLCC ______________________ PLCC
Chroma: ____________ RGB ______________________ RGB
Looking at that, resolution is better and output 12bit vs 10bit
but the other spec for me is better the 3mpixel, for what I know:
bigger pixel ---> better light sensitivity
1/2 inch is bigger then 1/1.25 inch ---> better light sensitivity
and about frame rate how many frame we can achieve with the 5mpixel at 1600x800 pixel? less than the 3 mp or the same? with the new sensor it will be fixed the problem due to the rolling shutter in witch, with large images there are some color/exposure difference from the right side and the left side of the picture? many thanks
Matteo
Old February 2nd, 2007, 01:20 PM   #405
BTW if someone is interested Micron is sampling a 4 Mpixel 250 fps sensor.
Last week it was listed at their page.Now it is gone.
So if someone is in contact with that company, you can ask for it.
http://www.photographyblog.com/index..._image_sensor/
http://www.fast-vision.com/downloads...salessheet.pdf
Part Number: MT9M440C36MT
PS: Anyway I see I was a little late with this thing, cause it seems Wayne M. talked about it in July, 2004
  You are here: DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
