High Definition with Elphel model 333 camera - Page 23 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
Old November 16th, 2006, 11:06 AM   #331
Originally Posted by Serge Victorovich
Wavelet Based RAW
That certainly would be cool. Aside from Andrey's work on Theora, the only similar free/open FPGA project I found was dwt2d -- no files were released though. Anyone else know of something similar?
Rob Scott is offline
Old November 16th, 2006, 12:52 PM   #332
Rob, google: raw to wavelet+open source ;)
Some useful links also:
http://www.compression-links.info/Wavelets
www.openraw.org
www.openfpga.org
www.doom9.org
Very interesting "geometric wavelets"
http://www.cs.tau.ac.il/~amir1/PS/gwcoding.pdf
Serge Victorovich is offline
Old November 17th, 2006, 05:41 AM   #333
A good post Serge. From my understanding, at lower compression ratio the quality difference narrows for standard Jpeg pixel format. The present differential compression should be a lot simpler and faster. But using wavelet for the differential over a number of frames should compress more. Cineform does this, and their Raw codec get around 6:1, but I do not know wherever that is just visual lossless or true lossless, as David's answers were a bit obscure. I imagine at least 3:1+ on average.
Their are many wavelet codec projects, their are an number listed on wikipedia, I posted a number of links here a few months ago. 2D and 3D inter frame Wavelet (used for security cameras and webcams) gets more, but I do not know if they are any good for visually lossless or true lossless. I had also been in contact with a guy from the BBC Dirac open wavelet codec (and FPGA design) they are good to contact (though they are normal codec so far).
Wayne Morellini is offline
Old November 26th, 2006, 11:17 PM   #334
353 update
I finished the tests I wanted to perform with the 353 prototype - upgraded FPGA software to version Xilinx WebPack 8.2i (it was not so easy to make it produce the same timing), updated some of our drivers to work with Kernel 2.6 (it was 2.4) and with new ETRAX FS processor. FPGA configuration works, attached 64MB DDR SDRAM - also OK. So now the corrected Gerber files are released in production.
Andrey Filippov is offline
Old November 27th, 2006, 07:55 AM   #335
Andrey, I still get people enquiring about projects like this. What is the new time line you expect for camera arrival, and any new additions and sensors that you might be considering?
It is hard to answer people about cameras when I'm not in the project and information is incomplete. If there was basic information on the performance, capabilities, limitations, and pricings of the camera, and the Digital Cinema projects surrounding it, I could simply point people there?
Old November 29th, 2006, 01:56 AM   #336
Wayne,
I'm trying to update development/production status here, and I do (usually) answer direct emails. At the moment I do not know the exact price (just hope it to keep about the same as it was for 333). I hope to have a first batch of the camera boards in about a month - it is now our highest priority.
The first sensor available with the camera will be Micron 5 MPix, older boards will need some modifications as the 353 board uses 2.5 V for the interface signals - not 3.3V as earlier models did. I am planning to use slower CCD (11 and 16 MPix) - similar to our model 323 camera, 8MPix - when it will be available from Micron, and have some work on dedicated hardware/firmware for compensating of the ERS effect of the moving camera.
We'll have info on the camera when it will actually be available posted on the web site, preliminary one - it is only here, in this thread.
Andrey
Old November 29th, 2006, 10:37 PM   #337
Thank you Andrey, but it might be more efficient to house a summary of the broad/preliminary information in one place (because it is very scattered and forgotten in this long thread) then repeatedly answering the same questions by email.
I have suggested to dvinfo in times past, for a modifiable sticky post, or link, at the head of threads like this, for the same reason. So, thread starters/moderators can post summary of where projects are, and save people reading through project threads. I think this can cut down traffic by 50% on these long threads too (or more).
Old December 7th, 2006, 08:08 PM   #338
Info about 353
Wayne, we can start something on our wiki.elphel.com about that. Now I'm pretty busy with new hardware development - several new boards will be released soon.
Old December 9th, 2006, 09:44 AM   #339
Cool!
Old December 12th, 2006, 01:18 PM   #340
2 new additions to 353
I finished Gerber files for 2 new boards - one with 8 Compact Flash slots and the other has FPGA+DDR SDRAM (64MB) - exactly like on 353 board and 4 flex cable connectors (one - to 353, 3 - to sensor boards). It allows to attach up to 3 sensor boards to a single 353, making it possible perform some image processing there (i.e. stereo).
Old December 12th, 2006, 05:15 PM   #341
Nice, now I just need a PCI interface to connect the camera to a PC and get higher bandwidth than 100 Mbit and have greater flexibility.
That way I can really make a camera system. :)
Juan M. M. Fiebelkorn is offline
Old December 14th, 2006, 01:19 PM   #342
Hi all,
What do you think about this one: using a small camcorder for viewfinder (as close to the Elphel as possible, its lens set to the same distance) and a usb numeric keypad plugged into the Elphel to control the recording? We won't be able to record sound tough.
Zsolt
Zsolt Hegyi is offline
Old December 14th, 2006, 02:19 PM   #343
How about the Nostromo SpeedPad N52?
Old December 15th, 2006, 03:01 AM   #344
Sounds good but we need linux drivers - the article doesn't mention it. If we can use it as a regular keyboard then it's ok.
Zsolt
Old December 15th, 2006, 06:05 AM   #345
Without a driver it generates keystrokes and mouse wheel events. It looks affordable, too, at around $20.
  You are here: DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
