#316 | ||
#317 |
Good ideas guys.
Andrey, I know that you are somewhat into sensor design, I am not, but I had a few ideas today, and some older ones. I was thinking that the sampling mechanism between four or more Bayer sensor pads could be shared, reducing fill factor. Using a multiplexer, the inputs of different pixels could be sampled sequentially or combined into different combinations producing an new value for binning and even debayering (4Mp binned 2*2 to either red green or blue for 720p bayer for that position). Because of the speed of internal sample the delay between pixels should be minimal. A larger number of pixels could be shared depending on noise induced on trace length, to further reduce fill factor loss. A large amount of data could be fed out in parallel because of the serial digital data nature. If you used a serial like A/D conversion, the fill factor loss could be reduced to a few percent. I turned to the thought of storing charge, and realised that the chip manufacture process is compatible with extra Vapour layering (or magnetic level layering). To stop over charge effects, the sampling method gives some resistance of course, but then continual sampling and dumping/discharge of over charge would give further resistance, but an over charge sink can be made to earth it (I have a unique process to do this (to handle large amounts of over charge) but it has greater potential and I have this in mind for other things). The circuits can be protected and the pads can be covered with layers promoting light gathering and capacitance. This allows for very much capacitance. I realise that some of this sounds suspiciously a bit like a CCD and existing cmos methods, but I think it is an alternative method that can easily be added to a cmos assembly line without having to substantial change existing components, and keeping it open for production runs of other normal chip items. What do you think about this process, your comments? Thanks Wayne. |
#318 | |
#319 |
That's O.K.
I saw your paper on some sensor function some time ago, and thought you might be into the senor hardware side. Thanks Wayne. |
#320 |
Dear Wayne
Do you have a glue about the Playstation 3 and the linux disk
in France maybe, maybe middle next year ???? |
#321 |
I have seen a news article about it. Somebody is preparing a Fedora based distribution. I suspect we will see a number. But before it is goign to be of use to us, they really are gong to have to have a method for normal Linux programs and codecs to automatically take advantage of the extra parallel processing power, or the developers are going to have to customise their codecs and other software. Which means somebody will have to ask them, or write it themselves.
http://news.spong.com/article/10969?cb=94 Ronald, I tried to email you a little while ago, to ask for some advice. Have you upgraded your mail redirection in your profile. |
#322 |
The new Micron sensor is only 1/2.5" of size. I think without a ground glass we won't have an adequate DOF. The 2/3" size is around the minimum that we could use. Their previous sensor with 1/2" size might have been worth a try (with different resolution and fps of course) but this has just became too small. Moreover, we lose 25% of the vertical resolution if we need 16:9 aspect ratio so in the end we get the size of a 1/3" sensor or even worse.
Any suggestions for a good GG? I've seen there are a lot of them on this forum - I just can't choose... All I know that I don't want any DIY stuff, I'll have more than enough work with the camera itself. It is also a good question the maximum aperture we can use with the C-mount lens without causing problems with the sensor's microlenses. The GG and this aperture will add together to give the total losses of f-stops we'll have (that's probably around f1.5-2 if the glass loses f0.5 and we have a lens with f1.2). I suspect we'll have to use almost always the maximum shutter width the sensor is capable of, ie. something around 1/24 (this includes the readout time). This will cause motion blur as a side-effect. Luckily, the readout time can be really short with the new sensor. On 96Mhz it runs with 12fps on maximum resolution (as opposed to the previous sensor with a 48MHz max). We'll use it in 2x2 binning mode so 60fps can be reached in the planned 1280x720 resolution - this is especially good for overcranking. I suppose this readout speed doesn't cause rolling shutter artifacts anymore so that's good news. Andrey, what are your experiences with the new sensor? Could we do it as described above or you see some problems? Also, ony of my earlier questions left unanswered: can we create two simultaneous video streams in the fpga (one of them for the disk recording and the other for the network preview)? Thank you, Zsolt Last edited by Zsolt Hegyi; October 31st, 2006 at 01:05 PM. |
#323 | ||
#324 | ||
Zsolt |
#325 | |
Most of the static projects struggle to get HD resolution, so looking carefully through the threads for HD capable adaptors. Even moving ones, I don't know what the quality will be. Thanks Wayne. Last edited by Wayne Morellini; November 2nd, 2006 at 01:14 AM. |
#326 |
I've been browsing through the m-audio/e-mu catalogs and it seems like they don't write linux drivers. So we won't be able to connect them to the camera. I think the audio will have to be recorded with the pc instead (we need one anyway for the camera control/viewfinder functions).
Zsolt |
#327 |
Eliminating the need for a PC would be quiet good.
EMU and maudio are not the only ones, Terratac??, and a number of others exist. Try looking on www.via.com.at website under there Envy 24 audio processors for manufacturing partners and products based on them. these manufacturers also produce items like those. www.digit-life.com , may also still have reviews of such products (their reviews tend to be quiet good) but the companies mentioned are worth a look at. If you look through the linux stuff you might also find drivers and API's for the USB sound cards, even for specific models like the Audigy series (now much improved). I think I remember something about Audigy and Linux. You don't really need a computer, most of the work is now in camera. You could use PDA, Micro-controller board, Sony PSP, or something like http://www.gamepark.com/ pocket game machines (some are Linux). The PSP is the best, but not strictly open, it has re-programmable processing line they use for sound and 3D, sort of like FPGA a bit and has good processing abilities. It can provide controls through their own controls, and display, but the camera could give live video feed port if made that way. |
#328 |
Update on 353
Extra work was needed to make the board boot from the NAND flash - that software is not yet available from Axis. But that seem to be done and camera now boots Linux from its flash memory. Next week I'll be working on trying the FPGA,
#329 |
good luck
That sounds great and maybe a dream comes true.
A stupid question anyway.. for 10 minutes , the estimated disk space and sustained rate should be what about |
