High Definition with Elphel model 333 camera - Page 21 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
Old October 22nd, 2006, 03:19 PM   #301
Back on track
I had do deal with some events of a personal matter - that caused slowdown with the 353 project. But now I'm again working on putting life into the first unit, CPU+network+memory are tested, now we have to write NAND flash boot loader for ETRAX FS - it turned out that it is not yet available from Axis.
For those who are interested, I can email circuit diagrams - I don't want to post it until I'm sure it does not have errors (2 already found/fixed so far).
We also made some noise measurements with Micron 3 and 5 megapixel sensors and plan to make this software as part of the camera firmware. 3 MPix has about 22ke- full well capacity, 5Mpix - about 10ke- with rather low readout noise - just above a couple electrons (with high settings of analog gain).
Andrey Filippov is offline
Old October 22nd, 2006, 07:33 PM   #302
Andrey, if I was able to find funding and time to help with this project, what would I need to purchase and roughly how much would it cost?
Rob Scott is offline
Old October 22nd, 2006, 10:25 PM   #303
Rob, when somebody wants to help with the project we usually provide hardware free of charge, but I don't have any extra 353 boards right now. The one I'm playing with is (by tradition) mostly built by myself - only BGA chips are mounted professionally - I don't have an oven.
As soon as I'll test the board electrically (with minimal software running) we'll be able to order a small batch assembled - then it will go to developers.
Old October 23rd, 2006, 01:13 AM   #304
I would love to help, if I possibly can. In the meantime I will get familiar with the 333 source code. What else should I do/read up on?
Old October 23rd, 2006, 06:23 AM   #305
Andrey,
What did you find for noise average db and latitude, for 3 mpixel, and 5 mpixel binned to 720p?
Have you seen this brand, they have 170db latitude, and 0.001 lux sensitivity?:
http://www.hdrc.com/sensors.htm
http://www.hdrc.com/hdrctech.htm
Some of the demo pictures are pretty interesting, and I wonder when they will go HD.
Wayne.
Wayne Morellini is offline
Old October 24th, 2006, 03:00 AM   #306
Guys, is there any way for me to get a small video clip of the bayer kind of 10 bit bitdepth?
Andrey, I know I can sound really stupid sometimes but I will make this question anyway.
Is there any advantage about using an ATMEL AVR 32 bit RISC instead of the actual ETRAX FS?
Second stupid question:
http://www.latticesemi.com/products/fpga/
Lattice has some interesting and inexpensive FPGAS with gigabit output/input, is there any use for them inside the Camera framework?
Juan M. M. Fiebelkorn is offline
Old October 24th, 2006, 07:29 AM   #307
It's on my list of things to do :-)
Old October 24th, 2006, 11:07 AM   #308
Originally Posted by Wayne Morellini
Andrey,
There is virtually no information there, but I am not impressed. The logarithmic transfer function is an old idea easily implemented in CMOS sensors. Sensitivity - it is not so easy to fool the Nature - quantum efficiency/amplifier noise levels of the modern CMOS sensors (like Micron's) are not that far from the theoretical limit.
0.001lx? - easy, any regular sensor can do it with long enough exposure.
Old October 25th, 2006, 05:19 AM   #309
Rob, what is exactly do you want to develop for the camera?
Zsolt Hegyi is offline
Old October 25th, 2006, 06:06 AM   #310
I am open to helping in any way I can, but in particular I am interested in implementing cinema-related features. Andrey mentioned that the board would have an IDE connector; I would like to help implement writing to disk.
Zsolt, you mentioned working on a lossless compressor for the FPGA (to reduce the size of the the raw image data) and I'd love to help with that as well. I've never had a change to do any FPGA work and it sounds like an interesting challenge.
I'd also like to write front-end (or is that back-end?) software to provide a viewfinder/heads-up interface. Perhaps this would involve a modification/plugin for ObscuraCap; I'm not sure yet.
Old October 25th, 2006, 10:49 AM   #311
I just saw an announcement for Hitachi's new CinemaStar hard drives. They could be good choices to use with the 353.
Old October 25th, 2006, 11:04 AM   #312
I've seen a distinct lack of this outside of SD CCD's. It is also a matter of noise and gain, which CMOS is not as good at.
The QE of the Microns is about 40% or lower, isn't it (not to mention low fill factors)? I've seen a sensor with upto 90% QE, and experiments in recent years have succeeded in getting one photon to move two electrons (QE*2). Then there is loss from the color filter, and another advantage that the FF sensor had, was that because of the 100% fill factor, a microlens was not required, so very fast aperture lens could be used. Rai, that designed the Drake camera, could get F0.85 or something lens. So, there is a lot of latitude over what the Micron can currently do. If HDRC go HD can get some of this advantage I think it could be a sweet deal. I can't get a reply from them yet, I am interested in one of these cameras for my own project, and some research purposes.
Wayne.
Old October 26th, 2006, 03:37 AM   #313
Implementing my encoder is a one-man job so I'd like to do it myself. But if you can do the disk recording part (can be tough if the processor is too weak to handle two streams), that's okay for me.
The elphel already has the client which can be used as viewfinder, I suppose. It's not easy to write a streamer and our stream will be huge so, for starters, we should try to use the current theora stuff.
The problem is that the fpga will have to create two streams simultaneously and I don't know that the architecture and software will support that or not. Andrey?
And if we somehow manage to create two streams, the Theora will be very bad quality - I don't know if it will be enough for precise focusing. I'm afraid we'll have to modify the theora encoder too (maybe with losing all the color information) and that's also not very easy.
Zsolt
Old October 26th, 2006, 06:34 AM   #314
Sounds good.
The elphel already has the client which can be used as viewfinder, I suppose. It's not easy to write a streamer and our stream will be huge so, for starters, we should try to use the current Theora stuff.
I agree, no reason to reinvent the wheel. Perhaps a custom version of VLC? I'll have to look into the options.
I was thinking perhaps two modes --
  • Focus mode: No disk writes, high-quality Theora @ low frame rate (if necessary)
  • Capture mode: Disk writes, lower-quality Theora @ full frame rate
What do you think?
Old October 26th, 2006, 10:50 AM   #315
Sounds good.
You can develop the disk recording part with theora while I'm working on my encoder.
Follow focus would be nice but if there's no other way then we must do it like you've said.
Zsolt
  You are here: DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
