New 3-D camera (maybe elphel based ?)
Is this new product related to the elphel or Apertus projects ?
3D-one Home In case they use open hardware designs or open source code, they should mention and publish this. Thomas Kumlehn PIXEL PARTNER (R) Digital Film Recording, 3-D/VFX Consulting and openKMQ (3-D) project |
#2 | |
at $50k per camera, i doubt they will sell a lot.
you can still do better with two EX1. I am currently trying to build a setup with 2 small cameras. must be 3CCD (or CMOS), shoot progressive 1080 if possible and have a view finder (the easiest way to check convergence). the other way would be to build a image mixer to switch the components from 2 cams and feed the signal to a nanoflash recorder. still way cheaper. or to use an image mixer to mix composite SD signal from EX3 for example and feed a small lcd, just for convergence (add a led to drive shutter glass and you got the perfect setup.) and way cheaper than 50K |
Equal Opportunity Offender
Disarmingly similar to the starship Enterprise.
Andrew |
