2 macro's together?
I'm wondering if it's possible to put two 10+ macro's together?
I can't zoom in properly with my new camera with the current macro, so i'm not sure if another added macro will work... Thanks! |
It will work, but the more glass, the more problems you might occurs such as loss of sharpness, colour abberation etc.
Is this for the purpose of using a 35mm adapter? If so, i've been through this route before, one +10 macro is already problematic with chromatic abberation and edge falloff. if you add another, this will aggravate the problem. Your solution is to use a achromat. Expensive, but solves your problem.
Ted |
