how do you guys attatch you field monitors/LCD screens to your rig ? at DVinfo.net
Alternative Imaging Methods
Old July 6th, 2007, 01:53 AM   #1
how do you guys attatch you field monitors/LCD screens to your rig ? I have an idea .. i just thought maybe you guys have a simpe solution or would have some pics to share how you guys have done it. It would really be appriciated. My only convern is that my 7" LCD might be a little heavy and i'm not quite sure how i am going to support it ( properly ).Heres what i'm doing. Its still very rough but i thought i'd show how its coming along I used an L bracket wich i mounted onto a board in with i will mount the monitor onto, i had a small base plate with the same thread size for DV cams ( lucky ey ) wich holds the bracket under the HV20. The L bracket is thick so it wont have any dramas with the weight ( not that the 7' monitor will weigh all that much ) i am going to give the board a good sand papering ( you can see on the back side it really needs it) and paint it matt black befor i mount the screen, but i think it will work out pretty well. I've included some pics to show how its all coming along, hopefully will be painted by tomorrow and will post pics again, and once my screen comes ( flat scren LCD ) i will mount it and post the final product.
http://img2.putfile.com/thumb/7/18507585865.jpg
http://img2.putfile.com/thumb/7/18507585830.jpg
**update** attached monitor and its looking awesom ( well i reallt like it ) Just have to wait for the wood filer to dry a bit more and i will give it another sand and paint it black. pics attached :
http://img2.putfile.com/thumb/7/18601343562.jpg
http://img2.putfile.com/thumb/7/18601343521.jpg
Let me know what you think.
- regards Marty.
Martin Wichtmann is offline   Reply With Quote
Old July 6th, 2007, 07:56 AM   #2
Depending on the weight and size of the monitor, I might just just a ball joint and mount it in the threaded hole in the handle of my HVX. If I'm doing the run and gun thing, I picked up some quick release hardware from Zacuto... Zamerican arm, Z-mount (for the rails), and ZicroMount (for the monitor).
Jon Wolding is offline   Reply With Quote
Old July 7th, 2007, 08:58 PM   #3
painted the board black so its finished. put some pics up:
http://img2.putfile.com/thumb/7/18722371230.jpg
http://img2.putfile.com/thumb/7/18722371224.jpg
http://img2.putfile.com/thumb/7/18722371258.jpg
Old July 7th, 2007, 09:03 PM   #4
Images: 1
Originally Posted by Martin Wichtmann View Post
Well, looks like it gets in the way of operating the camera/tripod and kind of gives it a rough look, but whatever works ($$) right? :)
BenWinter.com
Ben Winter is offline   Reply With Quote
Old July 9th, 2007, 11:21 AM   #5
I've mounted my Nebtek/Marshall on my hot shoe on my camera and if I plan to shoot a very low/high angles then I attach it on a separate tripod for viewing using a manfrotto adaptor.
Canon XHA1, SGpro,Flip,FF, RR Mattebox, Nebtek V-R70p-HDA with Canon, Nikkor Primes 24mm f2.8, 28mm f2.8, 35mm f2.0, 50mm f1.4, 85mm f1.4, 105mm f1.8, 135mm f2.0, and 300mm f4.0.
Cary Lee is offline   Reply
