Adapters need camera lens to work? at DVinfo.net
Alternative Imaging Methods
Old June 21st, 2007, 12:22 PM   #1
Hi,
Do 35mm adapters (equiped with Nikon or some other lens) need the original camera lens to be filmed with? Or can you just install an adapter (equiped with a Nikon or some other lens) on a camera body, just body with no lens?
Jasper Blunk is offline   Reply With Quote
Old June 22nd, 2007, 01:03 AM   #2
The Mini35 is modular and adaptive sub-components in the optical relay stage, power supply and baseplate fittings, are offered to enable the adaptor to be integrated with in-built lens cams like the Sony HVR-Z1/FX1 family style or the detachable lens styles like the JVC HD100 or Canon XL families.
Old June 22nd, 2007, 09:07 PM   #3
You've posted this question in the P+S Technik Digital Image Converters forum. The answer depends on which P+S Technik converter you're referring to. The Mini35 mounts to certain camcorders having a built-in lens. The Mini35c and the Pro35 mount directly to certain camcorder bodies with their stock interchangeable lenses removed. Here's a guide to P+S Technik converters:
http://www.zgc.com/zgc.nsf/product/pstechnik
Hope this helps,
Old June 26th, 2007, 12:17 PM   #4
Jasper
You may be referring to the Redrock M2 - it uses the camera's own lens as the relay lens to dramatically cut costs.
Cheers
Brian
Brian Valente
Redrock Microsystems
Brian Valente is offline   Reply
