Any Released Film Theatrically with 35mm adapter? at DVinfo.net
Alternative Imaging Methods
Old June 16th, 2007, 10:44 PM   #1
Hi...
I'm in process of making a feature that will be released theatrically, using HVX200. I just want to know is there any other film released theatrically using 35mm adapter (sgpro, m2, mini35 P+S, etc) than Danny Boyle's 28 DAYS LATER?
I've heard that it will soften the image as the date is being printed on film. If so, by using a heavy Digital Intermediate, will it help the from causing more degraded image.
Any opinion or suitable workflow?
Farishad Latjuba is offline   Reply With Quote
Old June 17th, 2007, 12:57 AM   #2
Images: 1
Originally Posted by Farishad Latjuba View Post
Hi...
You are misinformed. 28 Days Later never used a mini35. There have been no widely theatrically distributed films shot on any 35mm adapter.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old June 17th, 2007, 01:59 AM   #3
But they use Canon XL1 and when I take a look at the Behind The Scene, they use XL1 with the modified attribute in front of the barrel and big mattebox. I assume it was P+S Technik product.
Old June 17th, 2007, 06:06 AM   #4
There is suppose to be a film coming to the big screen this summer...
The trailer is suppose to be played right before the new Nancy Drew movie...
http://www.sarahlandon.com/
Shot with the HVX/M2 combo... you can go to the M2 site and the dp talks about the process...
Gary McClurg is offline   Reply With Quote
Old June 17th, 2007, 06:06 AM   #5
See: http://www.imdb.com/title/tt0289043/technical
Chris Hocking is offline   Reply With Quote
Old June 17th, 2007, 06:15 AM   #6
They used an XL1 with the FD to EF adapter which gives the possibility of using EOS lenses. In those adapters light from the lens doesn't pass through a ground glass to create a 35mm illusion so they're not 35mm adapters.
They added a mattebox, of course.
Nowadays people tend to use experimental digital HD cinema cams before using 35mm adapters but there's another thread here talking about 4 movies for the UK TV using Sony XDCAM EX and Brevis. Those cams are not HVXs of course...
Jose A. Garcia is offline   Reply With Quote
Old June 17th, 2007, 07:00 AM   #7
Farishad, you might want to search in imdb.com (using technical section). I found a bunch of movies were made using mini35 and some using Redrock M2. And actually one movie is using Brevis, which is 'Heart of Now', will be released in 2008. But whether they're transfered to film or not, I'm not sure...
Ian Lim is offline   Reply With Quote
Old June 17th, 2007, 10:30 AM   #8
Not quite even that. They simply used an Optex adapter and put a Canon EC and EJ lenses on it. Just goes to show that some people still think that story is more important than picture quality. ;)
Old June 17th, 2007, 10:32 AM   #9
Hmm... the trailer and all the stills have a mask over them... hiding vignetting and/or soft edges?
Jon Wolding is offline   Reply With Quote
Old June 17th, 2007, 11:16 AM   #10
If you are talking about my thread. They were 4 short films shot using the JVC 201 and the Brevis with some shots on the sony xdcam hd, not the ex
Philip Bloom
Old June 17th, 2007, 11:29 AM   #11
Sorry Phil... My mistake.
Old June 17th, 2007, 05:42 PM   #12
Images: 1
Again, you are misinformed. They attached their own lenses straight to the bodies of the XL1's, rather than using inferior stock lenses. No P+S Technik product was used.
BenWinter.com
