Son of more letus at DVinfo.net
Alternative Imaging Methods
Old May 1st, 2007, 04:47 PM   #1
Disjecta
Son of more letus
For those of you not getting tired of the same old thing, here's another one minute nature piece :)
All shot with my 100mm Nikon 2.8 lens.
Preset: VIVIDRGB with the following modifications:
Color Gain: 0
Sharpness: 0
HDF: mid
This is my default setting for the Letus.
http://www.pinelakefilms.com/XHA1/sunday_720.wmv
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline   Reply With Quote
Old May 1st, 2007, 05:05 PM   #2
Steven, out of curiousity, are you running image stabilization when you use Letus. Vibration from Letus concerns me sometimes. I can't decide what works out better.....
I will check out latest at home this evening.
Chris J. Barcellos
Old May 2nd, 2007, 02:33 AM   #3
Great clip, and I love the music too. You still have a few days that haven't been filmed yet... Look forward to seeing those!
Glenn Thomas is offline   Reply With Quote
Old May 2nd, 2007, 04:49 PM   #4
Disjecta
Chris, I don't use the OIS to stabilize anything related to the Letus. In fact, I don't recommend you use the OIS at all while using an adapter. The subtle movement of the ground glass will confuse the OIS and what you will see is a huge shift of the target 35mm frame which will show the borders moving up and down, left and right, at random intervals.
Old May 2nd, 2007, 08:03 PM   #5
Get the same thing on my M2 and really is a huge shift.
Noel Evans is offline   Reply With Quote
Old May 9th, 2007, 05:09 AM   #6
OT: All non-flipped dof adaptors will confuse the optical image stabilization systems because the image is inverted and physical vibration compensation works in exactly opposite direction.
Cheers,
T
Toenis Liivamaegi is offline   Reply With Quote
Old May 9th, 2007, 12:14 PM   #7
Wow, that is some of the best footage I've seen from a Letus. Which one do you have/recommend?
Mike Scotchinson is offline   Reply With Quote
Old May 12th, 2007, 11:03 PM   #8
simply amazing
Emil Habouri is offline   Reply
