Rails diy at DVinfo.net
Alternative Imaging Methods
Old April 30th, 2007, 05:45 PM   #1
Rails diy
Can someone point me to any rails diy tutorials?
Yev Belman is offline   Reply With Quote
Old April 30th, 2007, 06:58 PM   #2
I took 15mm aluminum rod and a die and threaded the ends of it, sandwiched 2 identical pieces of wood on either end with washers and bolts to hold it in place (perfect rectangle). I then made platforms for everything that goes on them and used small u-bolts to affix them to the rails:
http://www.yafiunderground.com/Images/rails.jpg
http://www.yafiunderground.com/Images/rails2.jpg
Web Youtube Facebook
Last edited by Cole McDonald; April 30th, 2007 at 07:01 PM. Reason: added newer pic
Cole McDonald is offline   Reply With Quote
Old April 30th, 2007, 08:13 PM   #3
i have a die/tap set. that'll work for the rods themselves. What did you use to interface rods to camera platform?
Once it's all painted black I guess it won't matter if components are aluminum, wood, or carbon fiber.
Old May 1st, 2007, 09:30 AM   #4
1/4"-20 thread with a wingnut
to attach to the tripod, I took the hexagonal mounting doohicky from my bogen head and screwed it to another board with u-bolts which then interfaces with the rails.
Old May 1st, 2007, 02:08 PM   #5
U-bolts idea is pretty clever. I did a quick search yesterday on McMaster-Carr and misumiusa for Shaft Collars.
Found this widget, a collar with clamp lever.. maybe a quick release.
https://fa.misumiusa.com/gwos/catalo...ODUCT_ID=10132
No price, need to register first :(
