A way to reduce the size of M2+GY-HD100 ? at DVinfo.net
Alternative Imaging Methods
Old February 27th, 2007, 08:30 PM   #1
Hi
First sorry for my bad english.
I am thinking to bought the M2 and wait money to buy it. I have a JVC GY-HD101E. On the photos of this camera and the M2, it seems to be a monster, the JVC lense is too big !
I see on internet the Zörk nikon adapter for JVC camera.
http://www.zoerk.com/_deutsch/adapt2jvc-E.html
So is it possible to put off the JVC lense and replace it by a little nikon lense to reduce the size of the system ?
HD 100-->Zörk adapter-->nikon lense-->M2-->nikon lense
If it's not a dream, what lense is adviced ?
Francois Bontemps is offline   Reply With Quote
Old February 28th, 2007, 07:08 AM   #2
if you buy the Zörk adapter, you don't need the M2. it gives you the same D.O.F as a M2 gives.* Better still, no light loss and the image stays upright.
*Note from Admin: As pointed out below, this statement is absolutely false. Normally we would simply withdraw this post from public view, but that would have confused the thread since so many other posts reference this one. So, we decided to leave it in place along with this disclaimer.
David Chia is offline   Reply With Quote
Old February 28th, 2007, 07:58 AM   #3
Isn't the Zörk going to give you a very large magnification though if you use it alone? The Canon EOS adapter for Canon XL1/XL2 for example gives you a magnification of about 7.2x since the 1/3" image sensor is so much smaller than the 35mm film plane.
Ron Lemming is offline   Reply With Quote
Old February 28th, 2007, 08:21 AM   #4
In order for a lens system to have the same DOF as a 35mm-adapter or film a ground glass is necessary. Otherwise you would just have a really long lens, like Ron says...
Steven Fokkinga is offline   Reply With Quote
Old February 28th, 2007, 08:37 AM   #5
Images: 1
Originally Posted by David Chia View Post
if you buy the Zörk adapter, you don't need the M2. it gives you the same D.O.F as a M2 gives. Better still, no light loss and the image stays upright.
Haha. Too bad this isn't true...all this talk about bokeh and grain can get to be quite the unhealthy obsession.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old February 28th, 2007, 12:33 PM   #6
"if you buy the Zörk adapter, you don't need the M2. it gives you the same D.O.F as a M2 gives. Better still, no light loss and the image stays upright." I heard it also records uncompressed HD to audio cassetes and had OIS that was superior to steadicam.
Charles Hurley is offline   Reply With Quote
Old February 28th, 2007, 02:59 PM   #7
Images: 1
No, that's EIS :)
BenWinter.com
Old February 28th, 2007, 04:05 PM   #8
ok... you guy's are being mean.....
your right... the jvc and a m2 look like a barracuda! slap a mattebox on that fish and you'd be longer than a f900! ( but $70k cheaper... )
you could use the zork nikon adaptor and a lensbabie3 ( http://www.lensbabies.com )
and get some very creative DOF.... but at 50mm, it will be on the tele side of the focal length.
You'd be the 1st to try it.... look up philip bloom here on the forums.... he's got a 201 and a brevis that makes some nice footage!.... and a nice bloke to boot!
Christopher Witz is offline   Reply With Quote
Old March 1st, 2007, 03:47 AM   #9
Would this act as a relay lens?
Andrew
Drew Curran is offline   Reply With Quote
Old March 2nd, 2007, 08:31 AM   #10
I wonder if you could use this 45mm Nikon or 40mm Voigtlander WITH an achromat (or screw on macro?) as a relay lens. They're both fairly wide lenses and since you need to zoom in on the GG anyways, the cropped image might still work.
Jon Wolding is offline   Reply With Quote
Old March 2nd, 2007, 09:02 AM   #11
those are a bit on the slow side...
one could flip a 50mm f1.4 around ( front to back ) and will mac a great acro/relay.
one thing to keep in mind is to make sure all lens surfaces have multi coating.... which help to eleminate internal reflections.
any modern name brande lens is multi coated.
contax/yashica mount 50 1.4's are a jewel for this type of thing. and since mount is out of production, one can find them cheap!
Old March 2nd, 2007, 08:20 PM   #12
There seems to be a few X-Fujinon 50mm f1.8 in the hockshops from time to time. I think these may also be obsolete but it was my first f1.8 lens and worked well. It might be useful to adapt as a relay lens.
A 50mm plus an achromatic dioptre works into the JVC HD100 and XL family of cameras. With the addition of a reversed biconvex element which seems to function as a condenser, this is Quyen LE's method for the Letus35.
Old March 3rd, 2007, 01:45 AM   #13
I missed a crucial detail... back focus will be a cinch, but you can't zoom in on the GG. So your relay will probably have to be specific to each model camera.
Old March 3rd, 2007, 06:41 AM   #14
There should be very little variation in the field of view of the groundglass image seen by the 1/3" CCDs of any 1/3" CCD camera receiving a directly relayed image. 50mm seems about right for a 22mm - 24mm wide image off the groundglass.
Wider SLR lenses in the region 35mm to 50mm would get you more area off the groundglass but might be harder to find used and new examples over-expensive in the wide apertures required.
They might likely very bulky as well to the point you might as well keep the Fujinon standard lens for relay.
You might also find that except for a 50mm, buying in the P+S Technik's own relay lens itself is competitive as to cost and is a better performer.
Last edited by Bob Hart; March 3rd, 2007 at 06:42 AM. Reason: Poor layout and missing letters. - Cheap keyboard.
Old March 3rd, 2007, 09:47 AM   #15
I've thought this, too. But can you buy it separately? From where?
