adapter how to at DVinfo.net
Alternative Imaging Methods
Old February 20th, 2007, 01:54 AM   #1
adapter how to
I used a 35mm adapter to shoot a short this past weekend and was blown away at the look it gave us.
so.. im looking for a good how-to or guide on making my own 35mm lens adapter. I looked around and liked the threads about other people's lenses but i havent really seen anything in the way of an actual set of instructions on how to make one.
David Hildreth is offline   Reply With Quote
Old February 20th, 2007, 02:06 AM   #2
For $50, you can get a full set of instructions and a ground glass screen (actually plastic) from the Redrock company, who also build the M2. I built one using the plans as a starting point, and then working things with my own changes.. See:
http://www.redrockmicro.com/products.html
Chris J. Barcellos
Old February 20th, 2007, 06:19 AM   #3
Hi Chris,
did you ckecked my free DIY 35mm tutorial on my homepage?
http://www.jetsetmodels.info/news.htm
Daniel
Daniel Schaumberger is offline   Reply With Quote
Old February 20th, 2007, 10:56 AM   #4
i checked your tutorial out, although i dont quite understand the whole vibration thing
Old February 20th, 2007, 11:25 AM   #5
David, maybe this can help you out, a true classic: http://www.mediachance.com/dvdlab/dof/index.htm
This remains as the ultimate DIY 35mm DOF adaptor basic knowledge base.
Cheers,
T
Toenis Liivamaegi is offline   Reply With Quote
Old February 20th, 2007, 11:37 AM   #6
Hi Chris,
Daniel
Hi Daniel:
Yeah, I have seen it before, and was trying to recall it for the response above. Didn't have you bookmarked.
Actually, I'm thinking this will probably be my next attempt, to build a vibrating tube adapter, because fo the need for a more run and gun adapter.
Chris J. Barcellos
