The Gs35
I just made that adpter name up, but here's a clip of a wax diffuser. All parts readily available through the internet and no glueing, hacking, sawing, grinding anything. Just screw on. I have a vibrating version coming around next week.
http://www.filelodge.com/files/room3...id%282%29.divx It's a divx file and only 40mb's big. I do notice spots on the screen. That's because I dropped the glass and it put little spots on it. No CC z76 Canon 50mm 1.8 |
What aperture was the lens at when you shot this? What was your light?
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G |
Not to bad at all, was this with the new achromat?
Cant really see CA or barrell distortion, just a little vignetting and the GG grain. Can you remind us of your setup? Also, I can see that your wax GG is not really diffusing enough, giving that hazy bokeh (sometimes known as ghosting). Unless you like that look, and it does give less lightloss this way, I would try a slightly thicker wax layer.
Thanks, Wayne. |
#5 |
Have you tried stopping the lens down yet? Just curious to see how far you get before grain becomes an issue -- it should be different for interiors and exteriors.
Looks pretty good, on the whole. Thanks for posting.
#6 |
The current lens I have for some reason doesn't stop up or down once it's locked. Any suggestions? I do have a nikno lens, but during my attempt to get the male/male ring off on of the thorlabs tube, it bent, not allowing me to use the Nikon mount. I do know, that with the Nikon 28mm f2.8 the grain was pretty noticeable. I wish I had the footage still.
Wayne. I'll look up the measurements for the macro and let you know. I'm not doubting your macro at all. The only solution I had was to pair it with another one. And even so, it's real nice because I don't have to zoom past 77 like I was with the cheap Opteka's, and much more crisp image. I'm sure the distance I have is too far because the holder I'm using is .5 inches long and the macro sits two step rings away from the camera. So just guessing here. 72-62-52ring(macro-.5inches)----then screen. I'd say the screen is at least an inch away because the thorlabs tube is 2inches long and it doesn't go all the way to the back. I don't have a condeser. I do think the most of the vignetting is from the screen being cut off on the edges some. It's in a UV filter mounted in, possibly. What FL pcx/dcx would you suggest? Plus the wax was/is not spread all the way. The sides have lots of weird things. It got beat around a lot. My cat likes to play with things that don't move??? I have some semi outdoor footage later if I can manage to stay awake. |
#7 | |
Thanks, Wayne. |
#8 |
Here is some more footage. The smaller clip is from a a day ago. The larger clip was from the same night as the previous clip with the fan, but not as much vignetting. I must have had it not zoomed in like I thought. Enjoy. More to come. Some with vibrating hopefully. Anyone want to take a stab at some POC material with me? I just don't want to spend that much on one sheet.
http://www.filelodge.com/files/room3...20/Video1.divx http://www.filelodge.com/files/room3...20/Video2.divx |
#10 |
Rich,
Please email me or PM my dvxuser account and I can help you out
Thanks, Wayne. |
#11 |
Some new grabs. New screen.
http://i57.photobucket.com/albums/g240/Car3o/Koty.jpg
http://i57.photobucket.com/albums/g2...3o/Sammy_2.jpg http://i57.photobucket.com/albums/g240/Car3o/Sammy.jpg Nothing CC all done in camera. Canon 50mm 1.8 |
