Various SGpro topics - Page 2 at DVinfo.net
Alternative Imaging Methods
Old June 21st, 2007, 05:46 AM   #16
SGpro r3 footage
Hi guys,
I shot some footage over the weekend with the SGpro r3 and my FX1. I hardly ever get a chance to shoot anything so made a nice break from assembling adapters :)
Below are some grabs, no CC:
http://www.sgpro.co.uk/Sequence%2001.jpg
http://www.sgpro.co.uk/Sequence%2002.jpg
http://www.sgpro.co.uk/Sequence%2003.jpg
http://www.sgpro.co.uk/Sequence%2004.jpg
http://www.sgpro.co.uk/Sequence%2005.jpg
My problem is I want to upload a video, but I cant find any good output/render settings. I am using Premiere pro 2 and captured using premieres standard capture (not cineform).
Im not sure to if I should output to quicktime h.264 or a wmv file. I try but it comes out really soft, and I want to show how sharp this footage has come out.
Would anyone be kind enough to share some output settings so I can show the footage?
I also have tests shot with 1/600th shutter that I would like to show...
EDIT:
I have uploaded a small version of some of the shots:
640x360 wmv, 96MB:
http://www.sgpro.co.uk/SGpror3_FX1.wmv
If people would like to see full res parts of this (say about 8 second clips), let me know which part.
I still need to upload the 1/600th shutter test....
Wayne.
Wayne Kinney is offline   Reply With Quote
Old June 21st, 2007, 09:31 AM   #18
What F-stop was each still taken with? ND? Cam aperture?
Will you be uploading full resolution pics and footage?
I prefer DivX .avi files... they look so much better than h.264 .mp4's.
Jon Wolding is offline   Reply With Quote
Old June 21st, 2007, 09:49 AM   #19
Hi,
The 50mm lens was mostly @ F4, the FX1 aperture around F3.5 with ND filter on.
The 85mm lens again @ F4, but the 20mm lens was wide open @ F2.8
Here are 2 full res clips:
http://www.sgpro.co.uk/Sequence%2004.wmv
http://www.sgpro.co.uk/Sequence%2003.wmv
Im just uploading some more stuff....
Wayne.
Old June 21st, 2007, 11:41 AM   #20
640x360 wmv, 96MB:
Wayne.
Old June 21st, 2007, 01:27 PM   #21
Thanks.
Bokeh looks good.
In both clips, there's a weird black outline on objects when they're in focus (wheat, left side of the man's jaw, right sleeve of t-shirt, etc.) they're in the frame grabs as well... what's causing that? The camera?
Old June 21st, 2007, 01:50 PM   #22
Hi,
Not too sure what you are refering to?
Wayne.
Old June 21st, 2007, 02:06 PM   #23
Maybe it's just me but I'm seeing a lot of grain in the out of focus highlights, they also seem a bit grey and murky as they make the transition form out of focus to focus.
Maybe it's the compression. Or maybe it's that I've been staring at a screen at the editors all day.
Stephen Pipe is offline   Reply With Quote
Old June 21st, 2007, 02:11 PM   #24
Stephen,
The grain (actually video noise) is in the uncompressed footage, coming from my FX1.
The murkyness is the wmv compression.
If you like, I can upload a low compressed quicktime of a short clip.
But, it would be nice if you could pop around again to test yourself, been about 2 years?
Wayne.
Old June 21st, 2007, 02:22 PM   #25
The only reason I noticed it in the first place is because it comes and goes.
Old June 21st, 2007, 02:26 PM   #26
Gotcha!
The sharpness setting on the FX1 is set to 12, maybe its too high.
Wayne.
Old June 21st, 2007, 02:55 PM   #27
Sounds like the culprit for the black edge and the bokeh grain.
Old June 21st, 2007, 03:05 PM   #28
Yeah, default is 8 (middle), i set it to 12, months ago, when i first got the FX1.
Maybe beyond the cams ability, huh?
Wayne.
Old June 21st, 2007, 03:14 PM   #29
I've never been impressed with Sony's affordable line.
Old June 21st, 2007, 08:49 PM   #30
Images: 1
And I've always been impressed with the SGpro. Really fantastic work Wayne. I'd be an owner long ago if I didn't have a vendetta against The Box design (shudder). Keep the sharpness at or below the 8 setting, and you should be fine.
BenWinter.com
Ben Winter is offline   Reply
