letus35 FE using canon lenses at DVinfo.net
Alternative Imaging Methods
Old October 10th, 2006, 08:33 PM   #1
So i'm kind of wondering if I should rent out Canon lenses from my local photography shop... I would like to, but then again, I'm not so sure because the iris stopped working on my current 50mm f1.8 lens when I attached it to the letus. I'm afraid that if I rent out all of these Canon lenses, the f-stop is going to stop working on all of them after I use them, and then I'm left with "You broke our lenses, the f-stop doesn't work on them anymore."
Any thoughts? Has anyone else had the same problem?
Sean Michael is offline   Reply With Quote
Old October 11th, 2006, 09:47 AM   #2
Are you using full manual lenses?
The iris wont work on a an AF lens.
Jim Giberti is offline   Reply
