Rod support at DVinfo.net
Alternative Imaging Methods
Old September 17th, 2006, 08:33 AM   #1
Rod support
Has anybody an idea of building a rod support system the DIY way?
Would appreciate any help. I´m from Germany and cannot buy the expensive cavision rods.
Matthias Miethe is offline   Reply With Quote
Old September 17th, 2006, 09:32 AM   #2
Here is my first attempt to build a rod system. Very easy nothing special.
The rods are 16mm diameter / 500mm long.
http://www.jetsetmodels.info/pics/selfmade4.jpg
http://www.jetsetmodels.info/pics/selfmade5.jpg
http://www.jetsetmodels.info/pics/selfmade6.jpg
Habe die Halterungen aus MDF-Platten gefräst.
Ich komme aus der Münchner Umgebung woher kommst Du?
best regards
Daniel
Daniel Schaumberger is offline   Reply With Quote
Old September 17th, 2006, 10:14 AM   #3
Ich studiere zur zeit in Regensburg, komme aber ursprünglich aus Potsdam bei Berlin.
Wusste gar nicht, dass sich hier auch Deutsche rumtreiben. Habe hier auch noch keinen mit 35mm Adaptern gesehen.
Hast Du einen?
Hast Du eine email?
Bis später
Old September 17th, 2006, 10:15 AM   #4
Respekt für das Rod system.
Oh forgot this is an english forum.
Looks really nice. How much did you paid for making this?
I´m really interested in getting a cheap version for rod support.
Old September 17th, 2006, 10:34 AM   #5
Hey, you forgot the biggest "Nervensäge" of all ;-)
Greetings from Darmstadt near Frankfurt.
Pretty clever little piece of rod system engineering for a DIY piece. Are you trying to honour the "made in Germany" quality seal?
Thomas Richter is offline   Reply With Quote
Old September 17th, 2006, 10:48 AM   #6
Hey thomas.
nur zur Info ich habe einen letus35adapter.
Habt ihr eine Idee für ein billiges support system, entweder selber bauen oder koofen.
Was habt ihr denn für adapter?
Greetings
Old September 17th, 2006, 11:16 AM   #7
Hi Matthias, klick on my name in the board and you can send me an email.
I have a little CNC-Machine at home from (http:www.step-four.at)
All things are made with it.
Daniel
Old September 17th, 2006, 11:19 AM   #8
Letus 35a. Vielleicht bald den SG Pro Rev2.
Bin gerade durch das Thema selberbauen durch, siehe den Canon EES thread.
Oh, sorry, English.
OK, here is a very basic do it yourself idea: I've started building a rod system this way, it worked pretty well, but if I get the SG Pro, I don't need one as it comes with the adapter.
Get Patex Power Knete (no clue how this is called in UK / US, but it is a two component plastic material that is made for glueing or modeling)
Go to a DIY shop like "Praktiker" or "Bauhaus" (German version of B&Q)
Get aluminium rods. They sell them with 12mm or 15mm diametre.
Get small nuts and bolts.
Take a plane surface (eg glass) that can get dirty and put some grease or similar stuff (eg "nivea" lotion) on it. Put also some nivea or similar on the aluminium rods.
Form the "power knete" (1 pack, 64grams) to one big flat blob (like when you bake cookies). Work on it some more to become a flat rectagular surface of roughly 4 times 8 centimetres, 0.5 cm high.
Put it on the surface.
Put the rods on top, with a distance of 4 to 5 cms. Align them.
Flip the edges of the "power knete" to go around the rods and go into the material on the other side.
Now, while the stuff is still soft, put the little nuts and bolds in, so they touch the rods with the one end but show out of the "power knete" on the other. These are the tightening screws.
Let dry.
Drill a hole to attach the camera with a tripod mount screw.
Build the other parts of the rod support system in the same fashion.
And if above was not so clear (apologies from my side), just imagine you are 5 years old again and you model you rod support sleighs with Play Doh ("Knete"). I'll post a picture of my creation to illustrate, but unfortunately I don't have it here, so it will be next weekend.
Ok, just a very DIY idea, very cheap (Patex Power Knete is around 7,50 EUR per pack, the two rods were 5 Euros ish).
Old September 17th, 2006, 11:21 AM   #9
oh no ... I was posting all this stuff and now Daniel has got excellent equipment at home...
In this case, forget about the play-doh option ;-)
Maybe someone else is interested.
