35mm adaptors only affect DOF?
Do the 35mm adaptors affect anything other than DOF?
Dynamic range, too. Provided they're made properly.
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G |
Angle of View if You will. You can use different lens which may have toghether with Your 35mm adapter wider or more tele focal length as Your camcorder originally allows.
#5 |
DOF provided by the adapter also has the added knack of obscuring background which DV tends to render poorly. The lack of resolution in DV makes backgrounds look bad so blurring them out completely using the adapter gives the impression of better resolution.
BenWinter.com |
#6 |
Yes Ben! I've always been distracted by DV's poor resolution where visual angle increases. Not only can you decide to omit an undesirable background, often an issue when you're not building $$$ sets, but attention is focused close, where DV resolution does look a lot better! Now if someone could analyze how DV compression itself responds to bokeh areas ....
#7 |
I had an early enthusiam for shining added light upon the GG either with white light or coloured but in the end it was not very useful. Seemed to have an effect of lessening contrast and bringing things out of black but was not very controllable and tended to aggravate flicker on my home made disks.
I haven't pursued this any furthur. |
#8 |
Hello JIM LAFFERTY,
Is Dynamic Range another term for "angle of view"? What is Dynamic Range? |
#9 |
The dynamic range is the number of steps from black to white. The human eye can see tons of range, 35mm film has about 1/10th of what we can see and DV has about 1/10th of that. So images tend to almost be posterized if they're not lit correctly, Digital wants good lighting moreso than film even.
#10 |
Thanks for the explanation Cole. It seems that these adapters do alot more to help use achieve the results we are looking for than just DoF.
#11 |
video has 5 levels of dynamic range.... does the adaptor increase it to 7?
#12 |
it cheats by lowering the lights so they fall closer to the darks and more within the range allowed by DV. we still have the 5 stops cause that's all we can get with DV period. It's just simple math/encoding technology, DV only can store a finite number of values for each color component. We, as videographers need to find ways to work within that limitation...and by controlling how much difference there is between light and dark, we can make it nearly indistinguishable from film...the only time it fails to look like film is when we get it wrong.
You can look at most video and see that the lights are blown out or the darks have no detail. To combat that, we need to underexpose our highlights a smidge (not much) and make sure we pour more lights into the dark parts of our frames. By lighting the shadows, we can get more details in our highlights while still having a more limited contrast range. We are basically stretching our mids by cheating our blacks up and whites down. |
