Project Possibility: Component/VGA/RGB/HDMI to GigE/Firewire/USB2 recording?
Hi
I have an idea, that might be suitable for a project if anybody wants to volunteer. I have been looking around for converters, that will take an uncompressed component/VGA/HDMI signal and convert it to a GigE/Firewire/USB2 data signal that could be read by a laptop, or a Ethernet Hard dive caddy, as a uncompressed/compressed stream or a file. In effect, a component capture device for HD cameras. All I can find so far is VGA/Component and HDMI through Cat cable extenders :(. I take it that these either use the cable fro analogue, or convert it to a non GigE readable format. So, does anybody know of such a beast fro GigE/USB2/Firewire, that a laptop can read? Project? --------- If there isn't any available, and if anybody is interested, it would make a good project. You should be able to fit basic 1080p and 720p through it (USB2/Firewire 720p). With some just minor compression techniques, even 10 bits should fit, or you can go dual GigE cable for even higher formats and bit depths, or 30p/50p shooting. The footage would be able to be compressed once dumped to a computer also. If you could program it with a cameras specific component data timings/format, or to auto sync and remember the, more can be done, as I hear some cameras have have custom formats that require less space (allowing more bit depth and 4:4:4) but can be processed into normal footage. You can literally use a ADC and little FPGA with GigE conditioned back end. Costing might be $100 on a DIY basis (+drives +portable mini computer/drive caddy etc). If you put a full lossless/near lossless FPGA in there it is might cost less then $500. Just one of the FPGA compression codecs (unfinished, not really lossless): http://en.wikipedia.org/wiki/Dirac_(codec) http://www.opencores.org/projects.cg...dirac/overview http://www.bbc.co.uk/rd/projects/dirac/ In the converter, we could configure each shot as a file through the normal Ethernet protocols, which the computer/drive caddy can automatically recognise and stream to disk, with little extra programming on the computer side. You might have noticed that one 100MByte/s GigE cable does not go into one 50Mb/s sustained hard drive, therefore two drives, and a caddy that does this would be needed. There is also the possibilities of compression, but at the moment the FPGA situation is a little bit primitive, but next year could spell something substantially different. These exiting cable extenders might have parts that might be useful in making something without FPGA. http://www.svideo.com/videobalun1.html http://www.svideo.com/ext-hdtv-cat5.html http://www.svideo.com/500010.html http://www.svideo.com/vgabalun1.html http://www.svideo.com/vgacat5.html http://www.myhometheater.homestead.com/vgacable.html This is not a project for me, but I am looking for people that might want to do it for us? Thanks Wayne. |
