Having "too much grain" issues? at DVinfo.net
Alternative Imaging Methods
Old July 22nd, 2006, 07:55 PM   #1
Images: 1
http://www.frozenphoenixproductions....vibrations.jpg
The analogy that comes to mind is the "rocket strapped to a station wagon" scenario.
Once I build a case this puppy will be ready to rock.
Ben Winter is offline   Reply With Quote
Old July 22nd, 2006, 09:18 PM   #2
haha don't put your best GG in there the first time you switch it on!
Stick some poc 20 in there, if you get eliminate the grain on that stuff you will have awesome bokeh.
Actually, just a thought - I think the that amount of vibration will cause you serious problems with tripod, cam etc etc vibrating in sympathy, unless you have a counterbalance. I have enough trouble with the coin vibrators causing image wobble due to vibration.
Andy Gordon is offline   Reply With Quote
Old July 22nd, 2006, 09:36 PM   #3
Images: 1
haha...funny thing about what's already in there...edmund optics 20 degree holo diffuser...
I'm going to experiment with that, and leave no stone unturned. If there's a way to get around the issues associated with that level of vibration, I hope to find it.
I already have a preliminary case ready, I just have to shape it the right way. My main concern is light getting in, and the massive vibration unhooking the sticks from their seating. Hot glue should solve the latter, hard work and time the former...
Old July 22nd, 2006, 11:35 PM   #4
That is a really aggressive eccentric mass. I don't think I would care to go there but don't let my opinion put you off the direction of your experiment.
To fix some optical issues related to vibration on the tripod, the centre point of the mass you are using will have to be directly over the centre pivot of the tripod you use, which is likely to make the tripod balance rear heavy.
With anything more than say a 28mm SLR lens, you will likely get an interlace artifact which will look like every second or fourth line actually reproducing the image. Keeping the moving mass over the tripod centre will lessen anything the tripod may cause.
Depending upon how flexible the whole assembly (SLR lens / mount >> GG enclosure >> relay optics >> camcorder) is, you will likely get some interlace artifacting anyway.
Converting your interlace footage to progressive will help with interlace artifacts but then there may also appear a periodic weaving effect in any direction, even circular, depending on how close to the frame rate of your camera the vibration period is.
Fixing some static mass firmly to the housing you put the adaptor in may help but artifacts introduced by flexing of the whole structure can only be fixed by stiffening the whole structure up.
This unfortunately is going then to transfer unwanted vibration to the camcorder lens servo-system, the cassette load - unload system and the SLR lens itself.
I think you would do well to follow Quyens lead, lighter eccentric mass, faster RPM, smaller excursions of the GG.
Old July 24th, 2006, 02:24 AM   #5
Ben, whats Your target? Getting grainless picture at small iris sizes?
Frank Hool is offline   Reply With Quote
Old July 24th, 2006, 11:14 AM   #6
Images: 1
Haha. I really don't know what my target is. That would be nice though wouldn't it?
I think Bob is right. This was mostly a joke anyway.
Old July 24th, 2006, 01:45 PM   #7
What GG are you using? Is it homemade because it looks like it comes in a ring like a UV filter, which is a nice touch.
David Delaney is offline   Reply With Quote
Old July 24th, 2006, 05:04 PM   #8
Images: 1
it's a 20 degree holographic diffuser from edmund optics. Diffuses nicely, wayyy too much grain. Thus the need for a lot of movement.
