Any shot anything with an FX1 - using a DOF adapter? at DVinfo.net
Alternative Imaging Methods
Old July 21st, 2006, 07:15 AM   #1
I am looking for some examples of films, docs or shorts shot with the HD Sony FX1 with a DOF adapter on it.
David Delaney is offline   Reply With Quote
Old July 21st, 2006, 07:34 AM   #2
Try a search for 35 and fx1 from the menus above.
Here's a link to a search I've done for DVinfo.
Link: http://www.dvinfo.net/conf/search.php?searchid=570495
The link is for fx1 with a Letus 35 adapter.
I own a Letus and happy with the purchase. Quyen is great at helping you out with any questions you may have.
Note that the link is only a search on fx1 and letus 35. You will need to modify your search for the other adapter tests.
John Kang is offline   Reply With Quote
Old July 21st, 2006, 08:08 AM   #3
Thanks, but there wasn't one clip with FX1 and the letus. There was a film-transfer, but nothing else. Checked through all of them...
Old July 21st, 2006, 08:35 AM   #4
One of my FX-1 customer's are currently shooting Peter Gabriel's new music video with the SGpro. He will be posting results in time...
Wayne.
Wayne Kinney is offline   Reply With Quote
Old July 21st, 2006, 08:48 AM   #5
Thanks Wayne, I have alot of respect for your product. The stuff looks great.
Old July 21st, 2006, 10:27 AM   #6
If you go here :-
http://savefile.com/projects.php?pid=618011
and scroll right down to the very bottom of the web page, the link to a clip is still there. It is a half-aize H264 clip so you will need quicktime or the free downloadable VideoLAN player to be able to view it.
The clip was shot with HDV on the FX1 for DVD "special features" but transcoded from the camera as MiniDV into the NLE for cutting, then recoded to H264 for placement on savefile.
Shot with modifed AGUS35.
( Prism erecting version )
(AO5 spinning groundglass disk)
SLR lens 85mm f1.8 wide open.
Sony FX1. (9db video gain, PAL, shutter 1/50th on-camera mike so bad audio.
Lighting - (production lighting for the production camera, a JVC HD100.)
Lighting consisted of a large theatre spot aimed at the ceiling, two 1000w lowels with filter gels and masks.
This clip has been sent along with other footage on a tape to Maheel Pereira in Sri Lanka who has developed a film-out process and is testing footage from various devices for filmout performance.
Old July 21st, 2006, 11:48 AM   #7
David,
Here is a pilot I shot with the FX1 and Letus35flip. We shot this at night with three 1k Lowel lights.
http://www.scottleemason.com/haunted...heCOMB_006.mov
Here is some footage from a short I shot with the FX1 and Letus35flip.
http://www.scottleemason.com/movies/slmGAFFERSreel.mov
That is all I have on the web. Hope it helps. let me know if you have any questions.
If you do a little searching there is a lot of stuff out there with the FX1 and DoF adapters. Look at the stuff shot by Macgregor at http://www.cinemek.com. That guy has some amazing footage with his FX1e and G35. I think there is some footage on the Red Rock Micro site also.
Mahalo,
Dusty
Dustin Cross is offline   Reply With Quote
Old July 21st, 2006, 12:44 PM   #8
I wonder how much the interlaced footage hinders the DOF...
Old July 21st, 2006, 12:58 PM   #9
I'm hoping to have some FX1/Z1U footage with a SGPro posted soon (like real soon). Right now, I have a short test reel of about 1 minute -- but I was hoping to do more. My next short will be shot with it.
Robert Kirkpatrick is offline   Reply With Quote
Old July 21st, 2006, 01:33 PM   #10
Images: 1
Why would it do that?
BenWinter.com
Ben Winter is offline   Reply With Quote
Old July 21st, 2006, 03:30 PM   #11
Well, I tried deinterlacing and find it makes the footage soft.
BTW Ben, didn't you used to have the Letus? Did you change your mind?
Old July 21st, 2006, 04:23 PM   #12
Images: 1
I did sell my Letus but apparently the focusing screen size/achromat power combination wouldn't allow a DVX to zoom in enough. The same issue arises with an FX1; I'm going to rebuild it and see if I can tweak it to better standards. Then I'll probably work an internal rechargable system into it and try to sell it again.
What did you use to deinterlace? I highly recommend DVFilm Maker as it is a very agile deinterlacer; it keeps very close to all of the resolution.
BenWinter.com
Old July 21st, 2006, 06:01 PM   #13
Ben I would recommend putting a condenser right in front of the camera lens. It has helped me immensely. I am finding that will the RedRock as well, vignetting - not sure why ,but I think the SGpro and the Brevis don't have the vingetting problem...true?
As for deinterlacing, I am using Video Vegas, separate fields etc.
Dustin, the first movie was amazing looking. Very sharp and even when it was dark - it still looked good. Did you get any vignetting with it?
Old July 21st, 2006, 06:18 PM   #14
Images: 1
Actually david the issue was that the focusing screen wasn't big enough--I was using the Beattie for the Contax which I guess crops a little too much. I'm experimenting with thin-film materials which should allow me a bigger projection area.
BenWinter.com
Old July 21st, 2006, 06:20 PM   #15
HI David
I made this post before in other section of this forum, but i think it's a good example for you of a 35mm adapter combined with FX1.
The adapter is M2 from redrock
www.yayofilms.com/video/boat_HD_720p.mov
Albert Rudnicki
www.yayofilms.com
Albert Rudnicki is offline   Reply
