35mm adapters for HVX200??
Does anyone know of any 35mm adapters other than the M2 which would fit on the Panasonic HVX200 HD cam? I don't like the results of the M2, bit too soft for my taste. I like the results of the Cinemek G35 but I gather it doesn't fit the HVX200. I have emailed cinemek but no reply as yet.. there doesn't seem to be much happening at cinemek so I'm not sure if they are still alive over there! Any suggestions appreciated :)
Brevis 35 with HD achromat.
how did the cinemek compare to the m2?
Matt, almost any adapter can work with the HVX, most people buy a step-up ring. 58mm to 72mm to fit into the HVX, if you have a good macro on it, then you should have to problem zooming on to the 35mm frame size. so any adapter that has 58mm or 72mm rings. its all good.
#5 | |
I will be KING! |
#6 |
We have a number of users using the HVX, which is my favourite of all the cams tested on the Brevis. I've had nothing but very satisfied feedback from these cam owners via email although there has been very limited evaluation footage posted so far, a situation soon to be remedied :-)
In addition, our "Revision 2" (pics in a few days) has rear xy adjustability and swappable (about 3 minutes) diffusers, as well as various subtle improvements. It's been an unbelievable grind getting here, but I know users will love the changes. |
#7 |
Dennis.
A commendable thoroughness move on the x-y adjustability. (I have been too lazy to do it for the PD150/FX1 but was forced to for the JVC HD100 on my own contrivances). If you have swappable diffusers, you may also now have the in-built choice of "no diffuser" and this opens up a whole new versatility for using much longer lenses in the f4 to f6 aperture ballpark. For the swappable diffuser option do you have an inbuillt "parking" or storage position within the appliance for the spare diffuser not in use? |
#8 |
Hi, thanks for the replies. Fantastic. Though I have decided that I will wait until the G35 comes back out or something similar. I have done a lot of research, and the G35's image is much nicer than any other adapters I have seen in that it doesn't appear to soften the image as much, and the overall image quality appears crisper and the type of "blur" is more what my eyes want to see. It's a shame Cinemek don't seem to be operating anymore- no replies to emails, or updates to their site. If Redrock started making an alternative adapter with similar results to the G35, I'd be sold :) I dont have much time to go into anymore detail right now, no offense intended to M2 or brevis lovers.
Matt |
#9 |
Just in case you missed any of the options, here is a list of 35 mm adapters:
http://www.dvxuser.com/V6/showthread.php?t=63484&page=2 it's with links to the websites, which are not always as organised as they should be. |
#10 |
Bob, there is no parking spot for the spent diffusers. They're pretty delicate, so I'd be loath to have them stored in the adapter. Once the testing is done on the new protype diffusers, they'll be shipped with a storage container which will serve as the safe place for diffuser elements.
I just had a look at some prelim HVX footage being done up by a pro shooter for us. The footage I looked at was amazing with respect to sharpness! |
#11 |
Dennis.
On reflection, that is probably a wise move. Anything which can be pulled free with fingers is going to fall free if it takes a hard knock. I know it well. "CLUTT!!, then what seemed to be an endless clatter and tinkling sound as all the bits of the disk rolled around in the case as it tumbled to rest. Then they got stirred up by what remained of the disk still on the hub, spinning like some demonic blender until I had the wit to turn the thing off. The front prism copped it as well as the back of the SLR lens. The mind image of the coating being chipped off the back of the rear lens element is not one to take a pleasure in at all. |
#12 |
I learned that lesson the hard and very expensive way with a few diffusers. There's nothing like money down the drain to motivate some CAD/CNC work in a hurry.
#13 | |
