GG Question for the Masters
I just finished mocking up my first "successful" gg adapter. It's a static adapter that uses medium format lenses to project on a larger 83mm dia focusing screen to reduce the relative size of the grain. My GG is an old series 9 skylight filter that I sanded by hand so the picture quality is much less than fantastic. I used 2 dcx fl 111mm lenses to get rid of the hotspot and the image is nice and bright. I lose about 1.5 stops with a f2.4 105mm lens (almost seems impossible). My question is what would be the ideal gg for this setup. I'd like it to be as sharp and bright as possible and I'm not overly concerned with bokeh.........yet. Thanks for the help, Jason.
A medium format focusing screen would probably serve you best. They don't diffuse completely and therefore give you a crisp, bright image at the expense of good bokeh.
http://www.intenscreen.com/products_medium-format.htm Browse through the screens they have available and pick one without any markings or split-prisms etched in it. I think you will be pleased with the results. I would suggest the Mamiya 83330 as one to look into.
BenWinter.com |
Thanks, i'm trying to do as little beta testing as possible because it can be quite costly. I've heard that the beatties were nice but I didn't want to blow 2 bills just to find out that the 400 grit is the shizzle. Thanks again, Jason.
400 grit's probably going to give you visible grain, even in medium format. If you're looking for a static solution, nothing lower than 1000 grit, in my opinion.
BenWinter.com |
#5 |
I have given up a static solution, however I got great results with a Beattie 83410 (Bronica ETR) medium format gg. It had no kind of hotspot and was very bright. Nearly no lightloss at all. Too bad the one I got was all scrathed so it wasn't usable. However, my dream config of an adapter is a vibrating Beattie as GG. My opinion is that it has to be vibrated otherwise the "fresnel rings" will show up in some light conditions.
Overall I find a Beattie solution appealing just because it doesn't require any kind of optics like condensers or similar, just a macro for the camcorder. I like simplicity.
http://www.nattvard.com |
