Only if this was 24p.. WOW at DVinfo.net
Alternative Imaging Methods
Old May 15th, 2006, 04:53 PM   #1
Use High Definition
By using a Digital Still camera you aren't limited to the low resolution of a standard-definition video camera or web camera. Instead of low resolution you can capture high resolution images and create high-definition video files.
This is a frame grabber right from the chip.... BUT not 24p.... man ol man..
http://www.granitebaysoftware.com/Default.aspx
Craig Bellaire
www.VerticalVideoSolutions.com
Craig Bellaire is offline   Reply With Quote
Old May 16th, 2006, 04:05 PM   #2
so wait its just a time lapse photo program?
Jeff Tyler is offline   Reply With Quote
Old May 16th, 2006, 06:54 PM   #3
correct. Youll get the same thing by standing there with your still cmaera snapping a picture every 7 sec or so.
That would be very very cool if it could be done 24 frames a sec. and you just need a huge drive to hold all the stills, and then load them to a computer program which recongizes the stills and puts them into order for you for playback. giving you high res 24fps.
Forrest Schultz is offline   Reply With Quote
Old May 16th, 2006, 08:48 PM   #4
yes
but I think several things must be adressed first... Now I don't have anyway electrical knowledge on how the chips work but if the signle from the camera is like "Pulsating" or only produces a picture every 1/2 second then even the software couldn't change that.... BUT... IF IT'S STRAIGHT UP HIGHDEF DIRECT SIGNAL.... then all that would need changing would be the software and codec... like mjpeg2000 4:4:4: lossless maybe this would be easer on a laptop then a tiff file.... Any thoughts
Craig Bellaire
Old May 17th, 2006, 12:43 AM   #5
This is nothing new really.
The chips are physically limited to between about 4 (for the highest resolution sensors) and 15fps at the full resolution, but neither the interface nor the internal electronics can manage this for long (it fills a memory buffer).
Cannon provide an API for controlling their cameras from a PC, so this sort of time lapse is actually a pretty trivial achievement.
Marvin Emms is offline   Reply With Quote
Old May 30th, 2006, 02:59 PM   #6
Time lapse
...and now some video cameras (I am thinking my new HC1!) let you take a pic every 1, 5 or 10mins and stores to memory in jpeg -about 2Meg so 500pics on my 1gig chip. Thats, 500minutes = 500/60 = about 8 hours or 500/24 = 20 seconds of 'footage' which can be imported into Vegas as a sequence strip...
Nick Outram is offline   Reply
