Music Video - DVX100a w/Letus35 at DVinfo.net
Alternative Imaging Methods
Old May 10th, 2006, 11:58 PM   #1
A little no-budget performance vid shot with DVX100a and the original beta Letus35.
Mainly used Canon 50mm 1.8. Used the 28mm on a couple shots
http://www.myspace.com/tomhowie
Lloyd Choi is offline   Reply With Quote
Old May 11th, 2006, 12:34 AM   #2
very nice... nice shots... good pacing.. dof is nice
Sean Michael is offline   Reply With Quote
Old May 11th, 2006, 06:41 AM   #3
I see some dirt in cirtain places. One(the biggest) is little bit right from center. Was it on the GG?
But nice work, really. Did You compensate edge fall-off? Asking because i can't determine wich are 28mm lens shots. Usually they have very visible fall-off.
Frank Hool is offline   Reply With Quote
Old May 11th, 2006, 10:49 AM   #4
Images: 2
looked real nice. Did you use any filters or anything on the lenses outside?
Jeremy Hughes is offline   Reply With Quote
Old May 11th, 2006, 10:55 AM   #5
Yep, dust! the shoot before this there was no dust, but I realized that it somehow got in there when I started editing. Wasn't happy...
And the edge fall off is there... I should really enlarge the image to get rid of it. It happens both with the 50mm and 28mm, it just depends whether the adapter is aligned correctly or not. If it's a millimeter off, you'll see it sadly
