Letus35 and other lens at DVinfo.net
Alternative Imaging Methods
Old April 28th, 2006, 10:15 AM   #1
I'm a Letus35 owner (the older version). I'm happy with it using canon FD 50mm prime lens but I was wondering if anyone tried them with other mm lenses such as 28mm, or even 85. What would happen with the vignetting or the distorsion?
Mike Kim is offline   Reply With Quote
Old April 28th, 2006, 03:25 PM   #2
mike.. use every lens you can find.. i use wide, telephoto, zooms.. thats the best part of having one of these adapters.
video : xl2 / letus35xl / bogen 503
photo- canon 1dmkII - bronica etrsi
Andrew Todd is offline   Reply With Quote
Old April 28th, 2006, 04:31 PM   #3
In terms of vignetting, the wider lenses usually give more vignetting. 28mm lenses are ok, but start going wider like 24mm or 18mm, and you will certainly start to see some vignetting. It does depend on the lens, a 24mm F2.8 will vignette more then a 24mm F2.0, in general.
Wayne.
Wayne Kinney is offline   Reply With Quote
Old April 28th, 2006, 04:59 PM   #4
to avoid vignetting I only use lenses with and f-stop of f2.0 and higher
Tony Tibbetts is offline   Reply With Quote
Old April 28th, 2006, 05:28 PM   #5
Okay, I'm about to buy a 28mm or 35mm canon FD. Not sure which one yet...... but thank you very much for the advise.
By the way, here's something I shot using a sony minidv cam (1ccd) and the letus35 with a canon FD 50mm prime lens: http://www.ifilm.com/ifilmdetail/2722881?htv=12
Colors were corrected with final cut.
