My first test on my DIY GG (Need Help: Grainy-Texture) at DVinfo.net
Alternative Imaging Methods
Old April 13th, 2006, 10:41 AM   #1
Hi all! I am so interested to get DOF/film look with a DV Camcorder and I was trying to make my own GG these weeks.
Here's my first test shooting(with my "beginner" JVC miniDV, Lens Nikon 50mm F=1.4):
http://www.archive.org/download/mxcv...m_test_031.avi
I have tried different types of materials and methods to make the GG including:
-Using candles wax on UV filters(cos it is really difficult to get Microwax in HK, shop keepers did not understand what I want). The result: very bad.
-Armour Etch on HOYA UV filters, the result is better but the grains are still visible after four to five attempts from leaving untouched->brushed->gently rubbed by naked finger.
-800 to 1200grit Abrasive papers and thin Acrylic Plastic boards and protective CDs but the results is not acceptable cos of scratches.
-Then, I tried to use cheap, UNCOATED glass to make my ground glass with armour etch and the result is the best out of all the materials and methods I used. I rubbed with my finger (I'm lucky I dun have any allergy problems after touching the agent) gently and quickly and the grains are the finest I can get as you see in the video. That cheap glass is a piece of Microscope Slide (72 pcs in a box for only HK$20). It is only 1 -1.2mm thin! So no greenish problem so far.
NOTE: What I found is Cheap glasses performs much better when using Armour Etch compared to UV filters. I think that relates to the Coatings HOYA applied in the factory?
But I urgently need a solution on how to remove the fixed grainy-texture from my video. Sorry, I'm not choosing to make a spinning one. I remember a previous thread linked me to a page and I saw something called "Noise map", but I have no idea how to work with it at all? Please help!
Thank you all! :-)
Marcus Chiu is offline   Reply With Quote
Old April 13th, 2006, 11:04 AM   #2
Hi,
I recommend using 1000 grit aluminium oxide powder, and with a little water, grinding your microscope slide against another peice of glass with the AO/water mixture between the glass. You should get a nice even grind with a finer grain then with the armor etch cream.
Wayne.
Wayne Kinney is offline   Reply
