Another DIY adapter footage - Page 8 at DVinfo.net
Alternative Imaging Methods
Old April 26th, 2007, 08:29 PM   #106
Ha, thanks a lot Chris.
That was a big help. It made me realize that it's a process. My JVC HD100 has interchangeable lenses, i'm going to see tomorrow if i can get away with adapting straight the the body of the camera, without having to use a backfocus lens. Someone once told me it needs the backfocus lens, but i want to be sure, because that's another 1 or 2 stops i can have back if i don't need it.
I will definitely give your process a try. Also, those Nikon lens tubes seem like the way to go, can you point me to a good place to find those?
Let me know how yours goes... i'd love to see some test footage sometime. What camera are you using?
Thanks again, really.
Dale Backus is offline   Reply With Quote
Old April 26th, 2007, 09:58 PM   #107
Chris.
Well written.
Dale.
You are stuck with using some kind of lens on the JVC HD 100 for relay, whether it is the original which came with the camera plus a close-up attachment on front, or a smaller substitute prime lens.
Relay using the original camcorder lens and a +7 Century Optics 58mm in 72mm sleeve mounted onto the focusing barrel of the JVC lens is quite effective, certainly to the 720P limit of the camera. The whole thing is awkwardly long however.
The dioptre has to mount to the front of lens and not to the 82mm fixed filter mount because the lens barrel comes forward or backward as you rotate it.
The adaptor, I mounted to the 82mm filter mount which is part of a fixed shroud around the lens barrel the light shade fits onto. Watch for crossing the threads. This shroud looks like metal but is actually plastic which is why you cant clamp around it as the pressure deforms it onto the lens barrel and jams it.
The downside is that for this method you have to cut an 82mm filter thread into a custom adaptor mount which is not an option for many people.
The front of the JVC lens has anti-reflective flutes cast into it. This portion of the lens is also plastic.
While there is no thread there, one of the flutes is of almost the same diameter as a 72m filter mount so it is possible for testing purposes to carefully screw the 72mm achromat's72mm filter thread into this small ledge and have it bind in place.
Easiest is to hold the achromat square-on and rotate the lens barrel as the thread binds into place.
Optically, there is only a short range available in adjustable distance from groundglass to front of achromat. You can use the backfocus on the JVC lens to help find the groundglass if it is just outside the lens focus adjustment but if you use the backfocus to fix your final setup, your zoom movement will no longer hold focus.
Old May 1st, 2007, 10:23 AM   #108
Thanks a lot for the help, Bob.
An update for those who are interested:
I've been experimenting heavily with methods of microcrystalline wax as my ground glass. I'm using microscope slides for the glass, and microwax for the GROUND :). At first i tried a mixture of beeswax and microwax. It applied nicely, and i was surprised with the results, but i decided to give 100% microwax a try. The microwax is far more sensitive to the imperfections in the glass, so the main obstacle is coming up with a way to clean the glass PERFECTLY. I've been experimenting with methods, but haven't had a lot of time this week to tinker with that specifically.
I tried the microwax with two layers of double-sided tape, and that yielded a very nice finish. It was almost perfect and with much less noticeable grain the the beeswax and microwax mixture (about 5-95 mixing ratio) So even a small amount of the beeswax added quite a bit of grain. I'm not having trouble at all getting the capillary action to work with the microwax alone, but the evenness varies every time. I still strongly believe it has to do entirely with the cleaning of the glass. I then tried using one piece of double-sided tape between the glass, and it still worked, but with more noticeable "cleaning" marks. It wasn't bad at all, but it looked good because there was a substantial amount of difference in the translucency between the two. It seems you could almost get another half or full stop by cutting the thickness in half.
I'll be working on a test rig soon, so hopefully i can post some pictures and footage in the near future.
one question though... I chose microwax because that's apparantely (or atleast in some form) what MovieTube is using. I heard they use a mixture however - any idea how his system can result in such a grainless static solution, especially if he's not using pure microwax for GG?
Thanks guys...
Old May 1st, 2007, 10:48 AM   #109
Images: 1
Look for waxrex 2405. it's next to impossible to get, but it's a big rumor that is what g35 used and it's slightly yellow in color, another rumor that is what the color of the g35 had.
Rich Hibner is offline   Reply With Quote
Old May 1st, 2007, 11:12 AM   #110
Way way back in Noah's time or so it seems, when the earlier experiments were going on, I vaguely and probably incorrectly recall there was reference to the Movietube and boss screens. Apparently the magic potion was 15% beeswax in paraffin wax I think??????
Microscope slides look smooth and even but I think you will find that they are not dead flat, therefore between two, you will get variations in wax layer thickness. I found when grinding them for fixed groundglasses that there were high spots on them.
There is a correction to make on my previous post. I referred to a 72mm 7+ achromatic dioptre. What I neglected to mention was the the dioptre I used was a Century Optics 58mm filter mount 7+ in a 57mm to 72mm ring.
The diameter as applied to the front of the JVC standard lens was still 72mm as mentioned but so far as I know, it may not be possible to get a 72mm 7+ dioptre.
There's a few .jpgs of some old wax experiments of my own at
www.dvinfo.net/media/hart
right at the bottom of the list you will find at this address.
They were large CD-R sized spinning disks. Wax rules but I found it impossible to control the thickness evenly which resulted in unacceptable flicker of the image.
Old May 1st, 2007, 05:04 PM   #111
Very interesting - i heard in passing that Movietube used paraffin and beeswax, but then heard they used microwas. I looked around and learned that microwax was characterized by extremely fine crystals, which seemed ideal for a static GG, especially for HD. The paraffin and beeswax mixture seems like it would be terrible for a static solution.
Overall, what did you find worked best for you? You seem to have been around this topic for quite some time, i'd be interested to know what you think is ideal.
It would be VERY nice to figure out a static solution, but i wouldnt' sacrifice that for an inferior image. I went through the Agus thread a bit, and he had some amazing looking stuff. Can you buy Agus35's anywhere, or is there a tutorial on how to make them?
Thanks Bob
Old May 1st, 2007, 10:32 PM   #112
Half a day with my greasy fingers on P+S Technik's latest groundglass making machine to make a larger than standard groundglass would do me fine.
However, dreams aside, for home-building, real glass remains my preference, dressed with five micron aluminium oxide and a very slight backpolish with cerium oxide to pick up a little more brightness.
Wax is better. Jim Lafferty has been doing some interesting stuff with an alternative.
Most recently, I have seen some interesting fogging on lenses from bad UV cure cementing of elements. This is caused by contamination of the bond by unclean glass, stuff like oil or moisture. This fogging is transparent but experimentally might be provoked to groundglass opaqueness.
I'll leave that to others to play with as I am not too keen on toxic chemical exposure.
AGUS35 is more or less a generic expression of many of the designs. The original form is CD-R retail case, opaque CD-R disk, CD player motor and hub, switch and battery power, close-up lens if needed.
Jim Lafferty published a project box version a while back and the makers of the Redrock M2 publish a home-build project box design and support it with a supplied groundglass disk and dioptre.
For the home enthusiast with adequate manual skills, the project box versions are the most predictable in terms of acceptable results as the cases are flat sided and the right-angles and parallel faces are already accurately established.
This link is to a look around inside my own device.
http://www.youtube.com/watch?v=CnweOEEqlRY
There are other better and more thorough designs. The only thing that this one has going for it is capability to accommodate case build errors of up to 5mm.
Old May 3rd, 2007, 11:11 AM   #113
Ah, thank you for clearing that up for me.
Very interesting, i'm glad you got something that works for you. Any test footage taken with your preferred adapter that you could point me to?
We did run into something yesterday with our own stuff. We've been poking around our Letus35 HD100 ever since we've been flirting with the idea of making our own adapter. We took the GG out yesterday and compared it up to the light beside the wax GG i made a couple days ago.
The grain is UNBELIEVABLY more noticeable in the Letus GG. It could be somethin like 5 - 10 times more grain than the Microwax GG i made. The Letus is a vibrating method, as you probably know, so the fact that it vibrates lends itself to more grain as it is because no matter how fast it happens, it has to stop to change direction at some point, and it doesn't vibrate that quickly at all.
We're thinking we can replace the ground glass of the Letus with our Microwax GG, and get much better results. The Letus is a great adapter and provides excellent results, the abundance of grain at HD is really it's limiting factor, (besides the 1.9x zoom, which we'd REALLY like to not have...).
I'll let you know how it goes - we're excited though.
Old May 3rd, 2007, 12:53 PM   #114
You may be pleasantly surprised at what a wax groundglass will do for you in the Letus35. There will be no variable density flicker problem like you get with a spinning disk.
There are practical reasons for the smaller GG area scanned by the JVC HD100 and Canon XL versions.
The area is faithful to the motion picture film image size. The groundglass texture Quyen uses becomes a bit coarse at that higher magnification but there was never any cause for concern over ghosting from aerial image penetration.
He uses a reversed biconvex element between the GG and his relay lens, I presume as a condensor, so I would not expect edge or corner brightness falloff to become an issue at that magnification.
Depending on the thickness of your wax layer, you may get some ghosting from aerial image coming through.
The added mass of your wax GG may be a problem for the small motor Quyen uses unless you can find thinner glass or can devise an even wax layer on a single layer of glass.
The CD sized wax disks I made up were totally scitzo, either smooth or severely out of balance to the point of breaking the wires off the motor. They were less noisy than the single glass disk which is acoustically live. They were heavier and it took longer for the motor to spin them up to speed.
If there are any stray larger grains in the wax mix, these will show as soft-edged freckles when the groundglass is vibrating.
The microwax you use. Is there a product brand or description. The nearest thing I can find here is a water emulsion used for waxing apples and it does not work.
Old May 4th, 2007, 09:52 AM   #115
Thanks, Bob.
http://www.spwax.com/spparaff.htm
That's where i ordered my wax. I told them i needed a sample for experimentation purposes and they had the wax to me in a few days it was very impressive. I'm pretty sure i got wax number 19. It has the highest melting point of the 3 softer microwaxes, and i thought even though it was probably harder to work with, it would be safer to use outdoors inside a black metal tube. I haven't found i too troublesome to work with though. So far the only method of applying the wax i've used is for getting a thin layer between to layers of glass by using the capillary action method. I'm sure you know what that is. It works brilliantly, even with microwax alone (or, without paraffin or beeswax). The results are a wonderfully low-noise GG. The problem is though, the thinner the layer you go, the less room for error there is, or so it seems. At first i tried using two layers of DOUBLE-SIDED scotch (duct brand, actually) tape (mainly because it was nice to have the glass stay held together during prep). I had very good results with that, even with the microwax. It seems the quality of the application depends pretty much entirely on how well the glass is cleaned. I found (especially in the thinner applications) that there would be visible streak marks and such in the wax when it dried. These were streak marks that obviously weren't visible the naked eye though, so there's no way to tell before you do it. (i'm not really a scientist, so to me anyway)
Then i tried one layer of double-sided tape, and the the streaks were a little more apparent. I want to be able to perfect this amount of thickness, because i want as little light loss as possible. The double layer thickness of microwax compared to Quyens GG, has a more opaque value that i'm trying to get away from.
What did you mean when you said, "The area is faithful to the motion picture film image size." Are you talking about the area of his GG, or the area the actual imager picks up?
Also, what is aerial image penetration?
And lastly, since you seem to know your Letus... when you open the iris of the backfocus all the way up, you get some serious image distortion. Any idea why that is? I don't know what to call the image distortion right away, it's been a while since i've seen it, but it would be nice to use the top speed of the lens, if you know what i mean. Thanks a lot
Old May 4th, 2007, 11:09 AM   #116
Dale.
Thanks for the wax info. I noticed on the website there is reference to the wax being compatable with synthetic and non-synthetic resins. I wonder if it can be blended wth UV cure optical cement used for bonding doublets. If so that might be a partial means of stablising it against heat effects.
By aerial image penetration I mean if the groundglass is not opaque eough and you can see through it, therefore a little of the sharper aerial image gets through and can be seen by the camcorder as well as the soft focused groundglass image. - ghosting, a soft area around a more sharply defined object.
The image area or field-of-view aquired off the groundglass itself is dictated by the use of the 50mm focal length Minolta still-camera lens and the unmounted achromat Quyen uses on front of it and the imaging area of the 1/3" CCDs.
I stuck a 2/3" cam on back of the same Letus35 and did not pick up the GG frame edges. The result surprised me as I thought I would have picked up the edges of the mirror path as well.
I think it comes down to about 22mm to 24mm wide seen by the 1/3" CCD when a 50mm lens is used for relay.
With my own gadget on a iSony FX1, when I use a close couple and +7 achromat, it picks up the edges of the prism path if I zoom back furthur than about 40mm and this limits me to about 22mm - 24mm width off the groundglass.
The image area from the LETUS35 for Canon XL I have here was comparable.
The P+S Technik Mini35-400 I had a play with gains a bit more image width off its groundglass. Literature on the Mini35 a while back referred to an image area off the groundglass of 21mm but I think that might be an older version.
As for the distortion of the image on wide-open relay aperturethere are so many variables it would be difficult to pin it down without optical knowledge and some serious equipment. The Minolta lens is a still-camera lens designed for a 36mm image width at the focal plane.
In Quyen's arrangement only an 8mm (1/3") centre of the available image width is used, therefore the sharpest zone of many such lenses, the centre of its image is used.
There is an achromat on front which might introduce distortions at wide apertures, a reversed biconvex element about 15mm behind the groundglass which also might introduce distortions and how centred the biconvex element and the achromat are relative to the Minolta optical centre axis and to the 3CCD's on-chip optical centre axes is anyone's guess.
Then there is the CCD wedge itself which requires special optical design in the lenses feeding it because of its prism.
Still-camera lenses apparently are less likely to perform sharply at wide-open apertures than cine lenses. It is apparently an issue of design and cost.
Because the 1/3" CCD is using an 8mm centre out of this lens's available image arrea at the focal plane, any softness introduced by wide-open apertures is going to be proportionately magnified compared to what is apparent on a 36mm image from the same lens. I think this is something users will have to live with.
P+S Technik's own relay lens (apparently by Schneider-Kreuznach accordingto past readings here at dvinfo) is a very serious piece of optical quality by comparison to the Minolta consumer level lens on the Letus35. It is also very seriously priced. My guess is you could buy one and a half Letus35es for just the cost of the P+S relay lens alone.
This is where the cost-benefit debate begins and that is another story.
Old May 4th, 2007, 11:10 AM   #117
Also.. what is that thing the GG is mounted in, in the Letus. If i were to replace it, i might want to leave his GG fixture intact and make my own from scratch. Thanks...
Old May 4th, 2007, 11:31 AM   #118
The groundglass mounting panel itself which also carries the motor is something you would have to ask Quyen about. It could be a trade part from somewhere or custom made by Quyen or by a third party for him.
If I was substituting, I might be tempted to make one out of a thin clear heat resisting plastic and stick a second thin plastic or glass transparent panel onto it with the wax layer.
If you are going to take his motor out and change it into your replacement panel, the chances of you buggering up the little motor are pretty good. He has encapsulated it, an added tiny dropping resistor and the fine soldering connections with adhesive.
It is a tiny can motor and the little end panel which carries the feed-through solder tags/commutator brushes is only retained by two bent tags which are part of the metal case of the motor. These are not very robust and wll not tolerate much wrestling while you cut adhesive away.
Best to buy in another motor for your own customised groundglass carrier.
Old May 4th, 2007, 12:39 PM   #119
Hi Dale,
if you need a carrier for your groundglass. Just gimme a drawing.
I have a little cnc-machine that makes pretty cool stuff :-)
best regards
Daniel
http://www.jetsetmodels.info/news.htm
Daniel Schaumberger is offline   Reply With Quote
Old May 4th, 2007, 02:52 PM   #120
Yeah, we'll probably build one and use a new motor.
http://www.hobbyengineering.com/H3425.html
Will that motor do the trick you think? I have no idea how powerful Quyens is, so i have no idea if this one is strong enough. Thaaanks.
Thanks Dan, i'll definitely keep you in mind!
