Redrock Micro M2 or Cinemek G35 at DVinfo.net
Alternative Imaging Methods
Old March 26th, 2006, 01:37 PM   #1
hello!
From what I could realize Redrock Micro M2 and Cinemek G35 are the most serious choices in range up to 1000$.
which one should i take, anyone has better ideas?
anyone knows what is going on with guerillla35?
thanks!!!
poiu
Haris Sarajlic is offline   Reply With Quote
Old March 26th, 2006, 11:08 PM   #2
Brother you have a plethora of options all of equal quality, use the search button. These things are like coffee, everyone has their favorite flavors; SG35 mocha latte, Letus35 flip frappuchino, Redrock Chai etc.
Greg Bates is offline   Reply With Quote
Old March 27th, 2006, 01:37 AM   #3
mmm, I want a chai now...Off to make one ;)
My Website
Meat Free Media
Aaron Koolen is offline   Reply With Quote
Old March 27th, 2006, 07:41 AM   #4
Id like a Letus35 flip frappuchino with a flavour shot of xl.
video : xl2 / letus35xl / bogen 503
photo- canon 1dmkII - bronica etrsi
Andrew Todd is offline   Reply With Quote
Old March 27th, 2006, 10:56 AM   #5
Does every 35mm adapter need time to tune-up at every shoot ? read somewhere that M2 need to be check at every shoot. Seems very time consumming... i want to go fast !
Etienne Caron is offline   Reply With Quote
Old March 27th, 2006, 12:57 PM   #6
Images: 2
I havent had to mess with my letus flip much - I know my settings for the camera, check the batteries and the monitor and pretty much good to go.
Jeremy Hughes is offline   Reply With Quote
Old March 27th, 2006, 01:24 PM   #7
Images: 1
I agree Jeremy--my Letus requires very little, if any, maintenence and adjustment. It's basically attach, zoom in, hit the vibration motor switch and go.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old March 27th, 2006, 02:38 PM   #8
Étienne, if you’re not in a hurry to get an adapter, you might want to check the Brevis35, which will be out shortly, probably in a few weeks. That one should be low maintenance too.
François
Francois Poitras is offline   Reply With Quote
Old March 27th, 2006, 04:22 PM   #9
What you have to do with all of these is make sure you have no dust or particles on any of the glass, etc., and have your zoom and focus set correctly. Beyond that, you can go as fast as you can put on the right 35mm lens and focus. Be ready for the whole 35mm thing to put more difficulty into the entire production process though.
www.holyzoo.com
Steev Dinkins is offline   Reply With Quote
Old March 27th, 2006, 05:13 PM   #10
Hey guys,
Regarding the dust issue.
Many of the footage samples from the Letus adapters appear to have specks of dust, even on the new samples from the Letus35xl. I really like the idea of the XL version with the relay, but I am concerned about the housing unit not being sealed well. To Ben and Jeremy, I know you don't have the XL unit, but have you found that your Letus versions are difficult to keep clean????
On the samples from the RedRock site and Cinemek, I haven't noticed the specks. Maybe, it is an issue of those units being sealed more tightly???? I know the individual user has a role in the maintenance of the unit, but any insight from owners would be helpful.
Brian www.naturefootage.com
Brian J. Harris is offline   Reply With Quote
Old March 27th, 2006, 05:59 PM   #11
Well the choice would seem obvious because, well, Redrock's one actually exists and is proven.
My Website
Meat Free Media
Old March 27th, 2006, 11:17 PM   #12
Dobar dan Haris. My roots are in Pitomaca :-)
A few of the design goals for the Brevis were based on reports from different adapter owners regarding setup, and internal dust. I've also seen quite a few examples of footage coming from adapters that showed visible dust/particles etc. This is obviously up to the user to make sure everything is clean, but that should be limited to external cleaning IMO.
The Brevis will need one adjustment when first using it. That adjustment is to align the unit so that once screwed onto your filter threads securely, it will be upright, with the frame aligned. Once the adjustment ring is set, it won't be touched again on that camera. I believe the Letus is pretty similar in that respect.
The Brevis is sealed at both ends. Aside from the DC charge jack, it will be watertight, and completely dust sealed. Given the charge port issue, I guess you would call it splash proof, as a small amount of water there would not leak through.
From a recent report on M2 use from dvxuser.com (in the DIY section), it is clearly not a simple issue to attach the unit, and rails are mandatory. I would strongly suggest reading that report as it reflects real world use of the unit. It does not screw onto the filter threads (and given it's size/weight, that's probably a good thing).
To my mind, where possible, attaching to filter threads is a good idea, even when rails are required, to maintain optical alignment. This may not be an issue with a static shot on a tripod..but what if you're shooting from a moving platform/inside a car etc.? MPIC and Letus both attach via threads, and that's a good thing. I'm using a carbon fibre chassis combined with CNC aluminum parts to keep the weight/stiffness factor optimal, and to allow use without rails if required. If the GG is not centered properly during manufacture...clearly fastening this way is not the best idea.
Dennis Wood is offline   Reply
