#16 |
I have just realised another modification they could make to the HD2, an low light mode that automatically switches to 1280*360 or 640*720, 640*480, and 320*240 binning at 9mb/s for better low light performance.
One of the things that 9mb/s can not handle is too much noise (and motion to well) I think it is preferable, most of the time, to have 640*480 or 320*480, then macro blocking. If they can set the switch in when noise from gain adversely effects encoding. They could also use something like that for areas of high speed movement, as long as the objects has clean lines it should not look very noticeable. |
#17 | |
#18 | |
Are you using the HD or SD package from Redrock? |
#19 | |
Robert Batta my stock video portfolio : https://www.pond5.com/artist/skysuta Pond5 – the world’s first web-based stock footage marketplace – |
#20 |
Sanyo HD1+Redrock M2 samples
two uncompressed mp4 video
http://rapidshare.com/files/14273242/Sany0565___.mp4 http://rapidshare.com/files/14272038/Sany0562___.mp4
#21 |
Robert, how much light loss do you estimate you are getting?
Is this an GG like focus screen adaptor? Is it possible to remove the focusing screen in this adaptor and shoot some low light using the condenser (adjusted to whatever makes it focus) as an test to see what happens (not expecting much)? The question ask before about the speed of the CCD in this camera, slow to very slow without lots of noise. The announcement of the new HD2 camera indicates an big improvement, I forget how much but it was an number of times, I posted a link in the HD2 thread. |
#22 | |
The loss of light is about 1/2 to 1 stop. and yes this GG (rotation) screen adapter one more uncompressed (mp4) test video with Prost Tele 135mm f2.8 lens at f2.8 Sanyo HD1 setting: f3.5 , shutter 1/100, iso 50, wb sunlight no cc or postproduction http://rapidshare.com/files/15036342/Sany0651_walk.mp4 but sorry i dont no remove the M2 cinescreen (GG)...
#23 |
#24 |
Out of warranty Black screen HD1 adaptor suggestion.
I picked up an Canon 8 video camera with automatic zoom F1.4 lens system for $5. It gave me a thought, such an lens could probably be made to work on an black screen lens HD1 (preferably out of warranty and unable to be repaired).
Canon Auto Zoom 814 Electronic (has extra rubber hood): http://www.canon.com/camera-museum/c...2_auto814.html http://www.canon.com/camera-museum/c...auto814_s.html The target size of 8 is close to 1/2.5. An little is lost around the edges in still mode, 16:9 720p shooting should fit, and still might still fit in the circle of the lens image. Super 8 would be better. http://en.wikipedia.org/wiki/Digital_photography http://machinevision.navitar.com/pag....cfm?nav4=true A very nice site I found for general photography information. http://www.photozone.de/3Technology/digital_1.htm The lens electronics could possibly be adapted to respond to the HD1. The lens looks cool enough, Canon upmarket styling. But then again security camera, and digital still camera lens, could also be used. If somebody had a defunct Sanyo in Australia and would be interested in this, I could send the camera if they paid postage (the lens if I can get it off). |
#25 |
Back on track:
About the purely optical adaptor. The problem with converting an 35mm lens to an 1/2.5 inch target is that you increase the angle of light convergence and speed. Past an certain point, it will mar the image if an microlens array is present. If there is no microlens or other obstruction, as you increase speed, eventually the angle of convergence becomes so extreme that light bounces off the surface of the sensor chip. Something in the 3/4 format website that I saw years ago, occurred to me. It is something I had planned on doing too. They seem to be indicating that the lens system is designed to reduce/straighten out the angle of light hitting the sensor (immediate thought, are these lens very slow?). So that the lens has an system to make the light hit the sensor more direct on. If this is what is meant, such a system would allow the native DOF of the 35mm lens to be transfered through to the smaller sensor without excessive angles of convergence, with many sub f1.0 stops. Does this sound credible (had three hours sleep the previous night)? |
