35mm Adapter for Canon XL-series Camcorders...(directly mountable)? at DVinfo.net
Alternative Imaging Methods
Old January 25th, 2006, 11:51 AM   #1
forget the mini35 for a second.
Ok...
The current offereings of 35mm adapters are cool, and using them with the stock lens on a XL1/XL1s/XL2/XL-H1 apparently has shown favorable results. Using a straight adapter and a 20mm relay lens is probably even better.
But I say unto you.....
Whichever company designs a 35mm adapter that preserves 35mm DOF and angle of view that mounts directly up to the body of the Canon XL-series of cameras .... will undoubtedly .... hit JACKPOT!
I'm waiting for the 1st person/company to do that. Man, with the amount of XL series cameras floating around the Earth.....just think!
Just wanted to put that out there.
- ShannonRawls.com
Shannon W. Rawls ~ Motion Picture Producer & huge advocate of Digital Acquisition.
Shannon Rawls is offline   Reply With Quote
Old January 25th, 2006, 12:33 PM   #2
Shannon, yes, the subject is a hot one, and has been brought up here many times.
http://www.dvinfo.net/conf/showthread.php?t=57866
http://www.dvinfo.net/conf/showthread.php?t=56745
http://www.dvinfo.net/conf/showthrea...=XL+relay+lens
The word back in 2004 was that the P+S Technik relay lens was an f/1.0 priced at $1000 itself. I've seen only a few people experimenting with the relay, most recently...
http://www.geocities.com/afsproductions/index.html
And on RedRockMicro forums, this mysterious pic popped up:
http://www.holyzoo.com/000/images/ho...lay_For_XL.jpg
By far the least expensive solution is just putting an M2/G35/Letus35/MPIC on the front of the stock lens, but it's bulky and sloppy regarding zoom/focus settings.
I had good results with the 16X manual XL lens however, since I could lock in the focus using the backfocus/macro adjust for a sense of sure focus calibration. I prefer the 16X manual lens anyway, so I purchased a body only kit, and the 16X lens.
Any XL-H1 body only kits out there yet? :)
www.holyzoo.com
Steev Dinkins is offline   Reply With Quote
Old January 25th, 2006, 12:35 PM   #3
Quyen Le will be bring out his XL flip in a few months time. Will replace the stock lens.
Wayne.
Wayne Kinney is offline   Reply
