The Letus35 Redesigned :) - Page 5 at DVinfo.net
Alternative Imaging Methods
Old January 22nd, 2006, 04:21 PM   #61
Ben, how much did you pull the stoppers out? It looks like they are out all the way and being held my the glue - is this true?
If they are in slightly, how did you measure all four legs exactly so the FL?
Leo Mandy is offline   Reply With Quote
Old January 22nd, 2006, 05:59 PM   #62
Wow Ben, that's absolutely amazing. Nice work.
In light of this, does anyone know if Quyen would knock a few bucks off the price if I told him I didn't need the GG because I was just going to replace it with the Beattie anyway? I realize he makes these pretty cheaply as it is, but that would be a little less work (and expense) for him to not have to bother with it as he made it.
Joel Kreisel is offline   Reply With Quote
Old January 22nd, 2006, 08:53 PM   #63
Images: 1
Not sure Joel. He sells replacement GG's at two for $10, I think. I don't really think it would affect the price that much.
Leo, I approximated a millimeter on each of the stoppers, and left them in the rest--they're not pulled out all the way. I was contemplating doing that though. I measured the distance from the plastic mount base to the edge of the slide holder with a ruler on each of the stoppers, making sure they were the same.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old January 22nd, 2006, 10:01 PM   #64
Very impressive. If you didn't use any external light for those clips, I'm stunned.
The G35 beta unit I'm using needs about 5k of light to light a small room without underexposing at f1.4 (to be fair, your images were a bit underexposed and the last was very underexposed). That's with a dvx. For close ups, I'd say 1000w of light maybe, unless you need the background lit.
Matthew Wauhkonen is offline   Reply With Quote
Old January 22nd, 2006, 10:29 PM   #65
Images: 1
That test clip was shot at f4 on a 55mm 1.2 lens. I was trying to keep more things in focus to show sharpness, I guess I couldn't opened it up more--I have zebras on, but I'm just not that good at judging brightness, I guess. I have more test footage on the way.
BenWinter.com
Old January 22nd, 2006, 11:24 PM   #66
How much lighting were you using, though? If those were at f4, those results are pretty amazing.
Old January 23rd, 2006, 12:02 AM   #67
Well, that wouldn't be much of a difference as Ben pointed out. I would be more interested to know if he would make it with the Beattie in place if we paid for it. It looks like it's the best and maybe the only way to go.
Michael Maier is offline   Reply With Quote
Old January 23rd, 2006, 03:05 AM   #68
Indeed, that was my next thought as well. ;)
Old January 23rd, 2006, 06:45 AM   #69
Dan Diaconu's been using a vibrating beattie in his MPIC, regarded by some as the best adapter out there for any price, for the last year or so. They do work.
Ben, can you comment on z axis movement at all with your setup?
Dennis Wood is offline   Reply With Quote
Old January 23rd, 2006, 08:22 AM   #70
Damn I can`t wait my Beattie to arrive, ordered it from B&H for two weeks ago for my open source adapter project I`ve been researching and developing for two and a half months for now.
Now I`m a bit concerned about that F100 Beattie`s size I ordered.
Will it still cover full frame?
I`m developing my design around parts most available in near future (Contax RTS II were discounted like years ago)
I assumed viewfinder coverage of those two SLRs mentioned to have clear Beatties were quite identical in size, 96-97% per specs.
OT: Ben how did you deinterlace that that sample video? I`m assuming you have GS400. Damn perfect diagonal quality... Or was it native progressive? (DVX etc)
T
Toenis Liivamaegi is offline   Reply With Quote
Old January 23rd, 2006, 10:53 AM   #71
Toenis, he is using a Canon GL2, as can be seen in his first pictures.
Ben, is it possible for you to shoot the same scenes you tried earlier with the thin-film screen so I can do a better comparison of light transmission, sharpness and distortion? I would greatly appreciate it.
Alain Bellon is offline   Reply With Quote
Old January 23rd, 2006, 11:12 AM   #72
Images: 1
I'm not seeing any. Plus I don't think there's much, if any, z-axis give in the Letus design.
My kitchen has two halogens over the island in the middle and a few 60-75 scattered around the place.
I was planning on doing that today. It's overcast just like it was when I shot with the bag. I'm also going to shoot an EIA1956 with and without the cam, which is printing out now.
BenWinter.com
Old January 23rd, 2006, 06:05 PM   #73
Images: 1
Shot the outside footage today. It was a lot darker today than the other days though, so the footage will be slightly darker.
Also, the first few seconds show the image with the motor turned off, then turned on.
http://www.frozenphoenixproductions....estoutside.mov
That's all I got. EIA1956 tomorrow.
BenWinter.com
Old January 23rd, 2006, 08:34 PM   #74
Thanks for posting that Ben. Now more questions:
1. What are we seeing on the right side of the frame? Did you need a bit more zoom?
2. The bokeh has a what I can best describe as a "buzzing" quality to it. I compared it to some footage from my spinner, both raw and 3K wmv compressed...and I don't get this. Is this just quicktime compression artifacting? Maybe you could post a few seconds of raw DV up on filefactory or something similar...particulary when the green grass is out of focus.
3. My guess is that you're losing little if any in terms of F/stops with the adapter vs without? Would 1/2 stop be a good guess?
Ha, you've got leaves, we've got 1 metre of snow! Great work on this :-)
Old January 23rd, 2006, 08:37 PM   #75
Thank you Ben, looks very sharp!
