what to use as a relay lens? + my 35 adapter concept - Page 2 at DVinfo.net
Alternative Imaging Methods
Old January 27th, 2006, 06:52 AM   #16
hmm, in general what would produce a better picture: a prism mounted in frount of the relay lens (to turn the picture 180°) or a set of surface coated mirrors that would do the same?
i'm begining to abandon the prism idea and thinking about putting the prism in the viewfinder so i can still composite the shot.
or taking the camera apart and physicly turning the CCDs 180° :D
or taking the viewfinder apart and doing the same :D
special people, not special effects. big hearts, not big budgets
Rok Furman is offline   Reply With Quote
Old January 27th, 2006, 11:00 AM   #17
Surface coated mirrors should lose less light, but may be difficult for some builders to set up accurately and to keep correctly aligned. They are light in weight and tend less to injury from shock loadings if successfully installed without any structural loads placed on them.
Prisms already have their reflective surfaces set up accurately and are easier to mount. If the reflective faces are coated, then light loss can be reduced. They are however heavy and their mass requires much more robust support and insulating structures around them to cope with shock loads.
Don't give up on prisms or mirrors. Life is a lot easier if the image is upright into the camera.
Old January 27th, 2006, 05:11 PM   #18
i already tried rotating the ccds 180 (just for kicks, dont ask why), and the cables are just too short to accomodate a half turn since they're customized.
Letus35 Flip on HC1
FCP5 w/ Intel Mac Mini and Powerbook Ti G4
R.P. Cuenco is offline   Reply With Quote
Old January 28th, 2006, 04:41 AM   #19
i'm thinking of using this lens as a relay lens:
http://www.cbcamerica.com/cctvprod/c.../mono/125.html
it has an aperture control ring which will come in handy
i'll probably have a 36*24mm frame, such as in a SLR camera - is this lens enough or should i get a lens with a greater focal lenght?
again, what is the flange distance for the XL mount?
btw is there any other way to turn the picture around without prisms or mirrors?
R.P. Cuenco, i could put in longer cables :D
Old January 28th, 2006, 06:38 AM   #20
Check out the thread I just started on that very subject. I have a theory, but no conclusions yet.
Also, there are other kinds of prisms aside from pentaprisms that will do the job. In this case, a dove prism might be more what you're looking for.
Joel Kreisel is offline   Reply With Quote
Old January 28th, 2006, 11:56 AM   #21
The other prismatic option aside from a pentaprism plus a mirror is a set of two right-angle prisms (porro prisms are optimized versions with rounded corners and a slit in the middle to minimize internal reflections). The right angle prism coupling is the same you encounter inside binoculars. The penta prism + mirror is the configuration found in SLR cameras.
Both of these configurations can be achieved by mirrors alone placed at the same positions where the prism facets are.
Alain Bellon is offline   Reply With Quote
Old February 8th, 2006, 01:09 PM   #22
the progress so far:
http://users.volja.net/furmanr/35.avi
http://users.volja.net/potocnikda/35a.avi
it's only a concept build so the quality just isn't there... yet :D
the relay lens is the kit XL lens, but i'll replace it with a CCTV lens when i aquire one. i still have to rotate the GG, it's static for now :)
