A slightly different 35mm adapter concept - Page 7 at DVinfo.net
Alternative Imaging Methods
Old January 25th, 2006, 01:18 PM   #91
Ha, I requested samples today. I was looking at some a few weeks ago, but the POC news in the forum was not postive so I didn't bother. It's worth a shot. Now my guess is that a few of commercial guys are sitting back right now and saying "Tried that, waste of time....."
Dennis Wood is offline   Reply With Quote
Old January 25th, 2006, 01:43 PM   #92
Hehe, they will wonder if we are serious with all those requests.
I wouldn't be too certain with regard to the commercial guys, many of them are just like us trying out stuff. And I think there is ample opportunity to miss on details like thickness, material (polycarbonate vs. polyester) and diffusion angles. Get one wrong and you may think they all suck. :)
From my own tests, adapter aside, I believe that the screen material I am using at the moment surpasses everything I have seen (except for the Beattie) in terms of light loss. And my previous material was even up there as the smallest grain (but I got a rotational variance in the diffusion that gives bad bokeh). There is a material that already gives both great qualities but its not wide enough. (check out the Alternative screens thread)
Hey, I am an optimist! :)
Alain Bellon is offline   Reply With Quote
Old January 25th, 2006, 04:08 PM   #93
Alain, are you still testing the Office Depot tape?
Leo Mandy is offline   Reply With Quote
Old January 27th, 2006, 06:46 PM   #94
Latest shot at night out my window, porch light. I changed my condenser and got rid of the barreling I was experiencing with my rig. The light loss is about 1 stop maybe? Hard to tell, but definitely better than anything I have used before - home depot bags or anything like that is a great way to go.
http://dvstuff.250free.com/bag.htm
Old January 27th, 2006, 10:32 PM   #95
leo mandy can u tell me how u apply the bag...do u glue it or something?
also, we don't have home depot here, but would these bags u refer to be the variety that come on a roll where you 'rip' them off for veges?
BTW how do u gauge light loss?
Justin Tran is offline   Reply With Quote
Old January 27th, 2006, 11:35 PM   #96
Images: 1
I've found a few bags. One is a trash bag. Not the kind you buy from a grocery store, but the ones a grocery store uses. It's very large and clear. Also, a doughnut shop has these types of bags. They use them to pick up the doughnuts most of the time. The veggie bags are about the same I think but I thought they seemed different to me for some reason. I'm trying this adapter as well and would like to know something. Do you apply these "bags" to a uv filter and make that a "gg" or just use the "bag" alone and add some condesors/macros? This would be helpful.
Rh
Rich Hibner is offline   Reply With Quote
Old January 28th, 2006, 09:01 AM   #97
Yes, I just glued it to the surface of the CD.
Old January 28th, 2006, 08:48 PM   #98
In my initial experiments, I tried these shop bags as I had actually used one in a Muray 8/16mm home editor whose stick-on rear projection material had begun to peel off. Mine seemed to add a slight cyan hue but it might have been my imagination. Between two clear CD-R disks I found a flciker similar to the wax so I did not go furthur with them. If there is a better consistency of opqueness and thickness, one should perhaps give them another look.
Old January 29th, 2006, 12:22 AM   #99
Images: 1
So, would you guys consider this concept better for spinning/vibrating or for static?
Rh
Old February 14th, 2006, 04:07 PM   #100
A bit off-topic...
Where have you been hiding, Alain? You wrote some of the best trueSpace plugins around. Didn't know for sure if this was the real Alain Bellon or not until I saw that you had some images linked to your old site.
How's tungsten|SOLID coming along?
To get it back on-topic, nice images!
Frank
Frank Ladner is offline   Reply With Quote
Old February 14th, 2006, 04:16 PM   #101
Originally Posted by Frank Ladner
A bit off-topic...
Frank
Thank you for your comments. :)
tungsten|SOLID became a suite of 10 stand alone applications. The first one of them is about to be released.
Old February 14th, 2006, 04:17 PM   #102
Rh
I have been having good success in a vibrating setup. Leo has used it in a spinning setup. Some bag materials have really small grain so it could be used for static under certain conditions.
Old February 15th, 2006, 01:36 AM   #103
Additional advantages of vibrating light materials
I've just written some lines on the propagation of vibrations in 35mm adapters. Alain's low weight bag-approach might have additional advantages allowing lower propagation of vibration in the camera+adapter setup.
see:
http://www.dvinfo.net/conf/showpost....9&postcount=11
Daniel Apollon is offline   Reply With Quote
Old July 10th, 2006, 11:31 PM   #104
Some questions
Also, are there plans for this puppy to be found? The plans for a straight vibrating adaptor no longer exists at the links I found either. Gak!
Finally, the vegetable bag plastic, is it the real clear stuff or the frosted type?
Frank Howard is offline   Reply With Quote
Old July 22nd, 2006, 07:13 PM   #105
I found the Quyen Le plan that Craig Bellaire did for him.
It had moved to:
http://bellaire.homestead.com/files/..._Adaptor_2.pdf
And the question about the plastic bags was admittedly a brain fart from going from one thread to another on these adaptors. Doh!
