#16 |
I'm running QuickTime 7.0.3 and for some reason it does not play anything in the window?
I will try a few other things on my end, but really not sure what it can be. When you upload FTP the transfer has to be set to Binary instead of Ascii. That's the only thing so far that comes to mind as to what the problem can be. Let me know if you can think of anything. Thanks |
#17 |
Well we've established that the grain issue with the mini 35 is not because of a larger grain used in the mini 35 as opposed to the pro 35 (they are the same sized ground glass) I'm not sure of the numerical value of resolution (I got a lot of crap for guessing at numerical value earlier on a different thread) But from looking at both cameras next to each other I can say that the xl-h1 resolves about 33% more. But your results may very.
This relay lens is interesting, that may have been the problem we were having on "the signal" shoot (I use the term "problem" very loosely) as there appeared to be some non moving ground glass, on the camera or grain or something. I'm sure this wasn't noise from low light because we really noticed it in high-lights. I'll post more info on This thread: http://www.dvinfo.net/conf/showthrea...t=57376&page=6
I have a dream that one day canon will release a 35mm ef to xl adapter and I'll have iris control and a 35mm dof of all my ef lenses, and it will be awesome... Last edited by Nick Hiltgen; January 17th, 2006 at 08:33 AM. |
#18 |
Hi Levan, any update on the FTP upload? Let me know if there's anything you need from me.
Cheers. |
