Letus Image flipping developement - Page 2 at DVinfo.net
Alternative Imaging Methods
Old December 12th, 2005, 06:22 PM   #16
The top and bottom part is vertically align, just 1.2" away, thanks.
Quyen
Affordable Adapter
http://www.adapterplace.com
Quyen Le is offline   Reply With Quote
Old December 12th, 2005, 08:48 PM   #17
Hello!
Will there be a rod support system available for this new adaptor?
It sure looks nice...
Jimi :)
Jimi Colteryahn is offline   Reply With Quote
Old December 12th, 2005, 09:22 PM   #18
Quyen
The neutral density filter enables light in to be controlled without closing the iris on the front lens. It would be placed between the SLR camera lens and the gg. It makes it easier to control light without losing the creative depth of field effect of having the front lens aperture wide open.
Image path in my arrangement is :-
SLR lens >> Neutral density filter >> GG >> prism erector >> Achromatic dioptre >> camera.
Also, I chose to have the prism offset, down and to the left of the camera lens centre axis of the PD150. This places the centre of mass lower and makes it easier to use handheld. It also puts the noisy bits away from the camera mike if I use it.
Old December 13th, 2005, 03:21 AM   #19
Originally Posted by Bob Hart
Quyen
Bob,
I think Quyen meant controlling the light using the camcorders iris, which would not affect the DOF effect.
Wayne.
Wayne Kinney is offline   Reply With Quote
Old December 13th, 2005, 03:35 AM   #20
Many camcorders, as my 170, has built in Nd filter, so for example I can use it. I did some test in very bright location and I found 2 way:
1) if you want low DOF then you close the iris or use camera built in ND
2)if you want high DOF the you close the SLR iris.
Ok are not a huge discovery, but it could be useful to someone...
Marco Mezzalana is offline   Reply With Quote
Old December 13th, 2005, 05:02 AM   #21
Originally Posted by Wayne Kinney
Bob,
only problem is that if it's too bright (eg in a bright sunny day) then the image being projected on the GG could be blown out...
Justin Tran is offline   Reply With Quote
Old December 13th, 2005, 05:23 AM   #22
True,
Infact i think the P+S mini35 has its own iris, must be for the same purpose.
Wayne.
Old December 13th, 2005, 02:03 PM   #23
Looks nice Quyen. How much for this one?
I also remember you talking about an adapter with a relay lens for the HD100 and a HD adapter somewhere in the boards or in your site. When will those be ready?
Michael Maier is offline   Reply With Quote
Old December 13th, 2005, 10:33 PM   #24
Quyen,
I sent you an email.
The adapter looks to be very cool...any estimate on what this one will go for?
Jeremy Edge is offline   Reply With Quote
Old December 14th, 2005, 09:01 AM   #25
Wow!! =)
It seems you are a friggin' genius! :D
Can't wait to see your progression =)
Regards,
Andreas Rylander
Andreas Rylander is offline   Reply With Quote
Old December 14th, 2005, 02:37 PM   #26
Bob,
www.flmpro.com/samples/001.avi
It seems to on this sample.
Kyle Edwards is offline   Reply With Quote
Old December 14th, 2005, 02:56 PM   #27
Kyle, It looks as though the SLR aperture is being closed and opened, not the camcorders (or looking carefully, maybe a mixture of both), but the changing DOF you see is due to the aperture of the SLR lens, not the camcorders iris.
EDIT: On closer inspection of the clip, i think this is whats happening:
The SLR aperture closes, widening the DOF....then the camcorders iris is opened to make the image brighter, no change in DOF. The cam's iris is then closed again, no change in DOF....then the SLR aperture is opened again, shortening the DOF.
Wayne.
Old December 14th, 2005, 03:03 PM   #28
Link aiin't working for me ..
Eniola Akintoye is offline   Reply With Quote
Old December 14th, 2005, 06:52 PM   #29
I assure you it's the camcorder's iris being opened and closed.
Old December 16th, 2005, 05:50 PM   #30
I am start shipping this unit. $600 for the final price. Betatesters should email me for price and instructions, below is the first video of the first unit sending out. Just a test video to show the unit's work. No special lighting. Thanks.
Quyen
http://hadleymedia.com/35mm.mov
Affordable Adapter
