NEED HELP IMMEDIATELY! Please.... at DVinfo.net
Alternative Imaging Methods
Old December 5th, 2005, 08:43 PM   #1
I used my Mini35 for a hwile an dverything was fine. Then I wanted to shoot some stuff without it but when I put back the Mini35 to the camera it seems to be out of focus and the Focus assist doesn't work anymore. I have a Expo to go to tomorrow with my camera I reall;y need it fixed by then =(
Anyone has any idea on how to fix it? I read somehting about The Relay lens needing to be adjusted, ut I don't want to break the camera. It seems to work find 1/8" from being fully attached and locked, but as soon as I lock it up the focus is all weird and focus assist not working.
Please help ANYONE!!
Duke
Brian Duke is offline   Reply With Quote
Old December 5th, 2005, 09:09 PM   #2
it sounds like you just need to adjust your "relay lens" that connects to your camera. i assume you are not able to focus on the GG correctly?
Cody Dulock is offline   Reply With Quote
Old December 5th, 2005, 09:15 PM   #3
Correct =( I am not sure how to adjust the "relay lens." Do you know how to without breaking the Mini35? It seems fine when hold the camera 1/8" from the Relay lens WITHOUT pushing it all the way in and locking the units together.
Any ideas on what I can do to fix this horrible problem..
UPDATE!! I think I figured it out. The manual they gave me doesn't correspond to the JVC 100U so the Relay lens is a bit different. Think tis back to normal.. THANK GOD! =)
