Letus35a DVX100a footage - Page 2 at DVinfo.net
Alternative Imaging Methods
Old October 30th, 2005, 10:09 AM   #16
Images: 1
does ANYONE know the difference between the 35 and the 35A ?!!!!
BenWinter.com
Ben Winter is offline   Reply With Quote
Old October 30th, 2005, 10:31 AM   #17
Yes, I do :D
There are some updates have been done to the Letus35A.
- Resistor removed for faster spinning
- Better achromat
- We lately make the GG bigger a little bit for DVX100 version since it has problem focusing when it's not perfectly aligned. So if you place an order and have DVX100(a), please say so, this feature is free and if you have other camera and want bigger GG as well, please note with your paypal order.
Thanks.
Quyen
Affordable Adapter
http://www.adapterplace.com
Quyen Le is offline   Reply With Quote
Old October 30th, 2005, 01:50 PM   #18
Skyonic New York
so does the adapter fit directly onto the dvx or do you need a step up ring?
Robert Mann Z. is offline   Reply With Quote
Old October 30th, 2005, 01:53 PM   #19
You'll need a step down ring. The Letus35 has a 58mm filter thread, while the DVX has a 72mm filter thread.
Edit: had the dvx filter thread wrong.
Emiel Labree is offline   Reply With Quote
Old October 30th, 2005, 02:39 PM   #20
DVX is 72mm ;)
Lloyd Choi is offline   Reply With Quote
Old October 30th, 2005, 02:43 PM   #21
Originally Posted by Lloyd Choi
DVX is 72mm ;)
You're correct. My bad.
Old October 30th, 2005, 03:52 PM   #22
Quyen
Is there any possible drawback to having the larger GG? Otherwise I would think it should be standard in case we end up using a dvx or another camera that turns out to have a similar problem.
Aaron McMath is offline   Reply
