Just a whim--correct me if im wrong at DVinfo.net
Alternative Imaging Methods
Old September 19th, 2005, 12:27 AM   #1
a few rusty gears are turning---my knowledge on the ccd's, and whatever else that is required to capture images in these digital wonders, is very elementary, but im wondering is there a way to take two dvx's apart and wire in multiple ccd's into one dvx and allow them to capture one image? Or combine multiple cheap camera ccd's to stream into one image?Would this be feasible (cheaply and efficiently), what would be required, and could it be done?
cheers
Kumar Sharma is offline   Reply With Quote
Old September 19th, 2005, 01:02 AM   #2
Yes, it was done by Oscar Spier. He is using two video cameras to capture two halves of an image projected on a ground glass and then lines up the two images in NLE. Two consumer camcorders, two tapes, one final image from post. I am sure he could fill you in better. A brilliant idea.
Dan Diaconu is offline   Reply With Quote
Old September 19th, 2005, 03:22 AM   #3
Take a look
He has a small site at:
http://members.chello.nl/a.schultzevspierenburg/
He also has a very good ground glass technique.
Kurt August is offline   Reply
