Condensor Lens
Would these http://www.diyprojectorcompany.com/c...b5dd8386f38ecd work for an adapter? I dont really know much about anything and I just came across these. And I want to use the Nikon D screen but already with my tests by adapter gets a hotspot. So I know I need a condensor to even out the light.
You get a hotspot with a Nikon D screen? If so, what lens are you using? And if you're not using a Nikon D screen, don't assume that whatever you are using will be the same as a Nikon D.
If you're using a nikon D, that's very odd. They have built-in PCXLs that act as condensors. I get a very good image with mine.
BenWinter.com |
Ok sorry. I worded my initial question really horribly. I currently have a temporary GG(frosted plastic) and I get a hotspot. I assumed I would get a hotspot as similar to my current GG because I didnt know the Nikon D had a condensor built in. I am GOING to order the Nikon, and I assumed I would have to get a condensor too. I think I now realize I can just get the Nikon D by itself, and should have no hotspot correct? I am using a cheap pentax lens though, I will test it though when it arrives.
Thanks Jeff Tyler |
#5 |
Yes, it is a mistake to assume that a Nikon screen will act the way your frosted glass will.
Even if you removed the attached condensor I bet you won't get a hotspot with the Nikon screen. Ever look at what size your hotspot currently is? You might be surprised. |
