Thread Tools
Search this Thread
#211 | |
#212 |
web site...
Well I'm not sure BUT you can e-mail Quyen Le "quyentle at hotmail.com"
He's the best and very good about resoinding to e-mails... Quyen Le... I have a question... After I get my adapter in I might have to see if you can make one for a camera we have at work. BUT it uses 1/2 chips. It's a full size camera. I'm also not sure of the size image it might need yet. I'll get back to ya... Just thought I'd give you a heads up.... MAybe this is the start of the Letus35 PRO? |
#213 |
Sorry that my website is down. I have submit a ticket to the web hosting, hope it's up soon.
Marius, The curve on the achromat is not that bad. You don't need to put the achromat all the way down to the ring, you can use something to space it before applying glue if touching the cam's lens is your problem. Craig Bellaire Do you mean making one that connect to the camera's body? Thanks. Quyen |
#214 | |
Ah, okay thanks for fast response. You mention two different achromats. Is one better than the other? From what I can tell the only difference is the outside dimension. |
#215 |
They are basicly the same quality. Cardboard mod is also needed to increase image quality, thanks.
Quyen |
#216 |
What is the Cardboard Mod?
I thought I'd read them all. |
#217 |
#218 |
Not on Camera Body
We have a evw-300 3 chip Hi 8 camera. It has 1/2 chips and 800 lines of resolution. We use it to run into a dvcam deck for a 3 hour shoot. Anyway the camera lens has a macro on it... So the adapter I would think would go in front of the camera lens just like the 1/3 inch cameras or mini dv cameras.. I'll check into it a bit more next week...
