#16 | ||
Maybe it's just because I've gone the static route, and only the static route, and haven't encountered any results I didn't like (OK, maybe a few here and there but they've all been remedied). Create an intensive and detailed enough GG design, and I'd really confident that a completely working and reliable adapter can be made. |
#17 |
Here follows a bit of useless info to add to the useless suggestion I made about a photocopier reflecting lens. The appliance used during WW2 was called an epidioscope. It enabled slide-shows from printed photographs or documents.
#18 |
Ben,
I'd say you're just as accomplished as many of us here. Some are more experienced in messing with their adapters, some are less so (and less succfessful), and some are about on par. So, congrats! :) I wouldn't say "lower". Just newer to the club. As far as static not being accepted as having noticeable grain, it's a matter of personal taste. But, the one manufacturer bringing static shallow-DOF adapters to market (Guerilla35) has published raw footage and plenty of people are lining up to get their product. And Bob, that's not useless info! I found it intriguing and am curious to learn how it worked, since I assume it wasn't trying to treat the documents or photos as a translucent slide. Sounds very topical here. |
#19 |
The Guerilla35's static?! See, now that's awesome. What are they using?
I just recently bought one of Letus' vibrating adapters off ebay, and I look forward to trying it out and comparing the results. |
#20 |
Is that the Lettuce35? They use a cellulose focusing screen?
Alright, apologies for the cheap humor... it's late... The G35 uses static, wax glass, we're all pretty sure. I'm one of the people trying to perfect that technique (check out the "Microcrystalline Wax Techniques?" thread here for more info). I'm also trying to find sub 3 micron alumina to grind glass with as a comparison. I've got a great 3 micron glass here that has proven to be far easier to reproduce consistently, but when compared with (e.g.) Frank Ladner's or some of the G35 footage, the 3 micron results are unquestionably more "grainy." Not that the "average" viewer would notice, but I am something of an optical perfectionist at heart -- never want it to "get in the way." So, I'm waiting on a shipment of 1.4 micron alumina, having tested .3 and .05 micron (didn't prove useful -- too small), to see if the results from it will come within the same ballpark as the successful microwax tries. Meanwhile, also trying microwax and am getting closer and closer to a perfected protoype, but it is slow going -- figure on 1.5-3hrs and two $12 filters per try for microwax depending on how you cool and clean the glass, as compared with literally 15-20 mins start to finish and one $12 filter for aluminum ox. I've got much more info up on my site: http://ideaspora.net/oldskool - jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G |
