#16 | |
Wayne. |
#17 | |
#18 |
and the trv900
Hoi, very interesting ...
i tried this magnetic method on my sony trv900 - no reaction - am i using a lousy magnet or is there another method inverting the screen on an sony camcorder? greetz from Aachen, Germany Maximilian |
#19 |
Some cameras use a physical, nonmagnetic switch based on LCD position. Not all models of Panasonic camcorder seem to use magnets, either.
Last edited by Bill Porter; August 12th, 2005 at 06:50 PM. Reason: Clarification |
#20 |
I would've never tried this on my Optura Xi, but i figured since the GL2 works this way, I'd give it a shot. To my suprise, it works! Makes shooting with the adapter so much easier. Thanks.
And as a plus it is also automatically mirrored, so it's a normal image.
i can't yet see Productions |
#22 |
Also, some people have wondered why people with these adapters are shooting with a normal-sized LCD screen. Their arguement is, if you have to focus, shouldn't you need a larger, more detailed screen to decide what's in focus and what's not?
In a way, yes. But it's known that people with 20/20 vision cannot distinguish blurry artifacts that are barely noticed when blown up to an 8x10 and viewed at 1 foot. This basically equates to: if you have good vision and determine that something on the LCD screen is in focus, it probably is. Or at least no one will notice otherwise. You only really have to worry if you have really, really shallow depth of field. |
#23 | |
I have a 7.2" LCD and I can focus better than with the factory LCD. The simple fact is, small details are lost on the smaller screen because it has less resolution. So the big screen does help. Last edited by Bill Porter; August 13th, 2005 at 05:44 AM. |
#24 |
I got some small magnits from some magnetix thing I saw at target and I was wondering, how do I go about testing to see if it can be done on my camera? I held the magnet up to different parts of the lcd screen when its past the flipping point, then moved it back to position, I got no results but is that how you do it? Its really hard to do since the magnets aren't that small and obviously dont stick to my camera.
#25 |
problem with magnets is you always have the screen tilted up!
The problem with magnets is you always have the screen tilted up!
Thus you can't hold the camera above your head and film downwards. Also taping the magnet in place is tedious. A better solution is to simply unscrew the 3 silver screws around the lcd screen. Remove the back portion and then move the magnet sensor from the hinge position and tape it to the back of the plastic housing. Now you can velcro a magnet to the back of the screen and flip the footage much more easily independent of the LCD's angle or position. Peace, Rolland
Rolland Elliott |
#26 | |
BenWinter.com |
#27 |
I think you are mistaken
I think you are mistaken. There is no metal on the inside of the plastic housing, thus nothing to stick to.
I have my gl2 in front of me and just tried it.
Rolland Elliott |
#28 |
...nope, I'm pretty confident in my memory. Are you putting the magnet on the LCD between the LCD and the body of the camera?
I used a magnet like this: http://www.magnetsandhealth.com/cata.../neodymium.jpg and put it here (see attachment) on the part of the LCD just above the hinge. If it doesn't work for you, Canon has obviously changed their camera design since then.
BenWinter.com |
#29 | |
http://img.photobucket.com/albums/v6...g/DSC06881.jpg
www.bionicpix.com |
