cheap vibrating GG mechanism - Page 9 at DVinfo.net
Alternative Imaging Methods
Old August 7th, 2005, 07:59 AM   #121
Motor Test
The motor ran about 15+ hours, no problem. So motor problem is not an issue here. Thanks.
Quyen
Quyen Le is offline   Reply With Quote
Old August 7th, 2005, 08:12 AM   #122
Quyen,
I got a bunch of .5cc syrings and they are too small in diameter for the grommets, so I will have to upgrade to the full 1cc size! It slides too easily up and down and therefore too hard to get a good focal length.
Leo Mandy is offline   Reply With Quote
Old August 7th, 2005, 08:26 AM   #123
Leo,
Sorry that I gave wrong syringe size. I still don't know why I said .5cc. Hope you can get the 1cc one, thanks.
Quyen
Old August 9th, 2005, 12:40 AM   #124
Voltage
Some asked me what kind of battery / power supply / voltage do I use for this set up, here are my answers:
- I use 1 1.2v rechargable battery, 2 battery will cause a lots of noise yet don't solve grain problem as good as 1 battery.
- If you want to use 2 rechargable battery which is 2.4v, use 1 resistor about 15-25 ohm (I am using 18 ohm) and connect it in serial with the motor.
(+ resistor motor -)
- Use 50 ohm variable resistor will be the best choice since you can find the best voltage setting for your system with different shutter speeds.
I wonder if anyone has successfully built this adapter?
Hope this info will help you further in building a working one for yourself, thanks.
Quyen
Old August 9th, 2005, 03:48 AM   #125
I have ordered one of Le's adapters and even though I haven't received it yet (a few more days, hopefully), I just want to thank Le for the great customer service he gives. So far every email I've sent him, he's replied almost immediately with answers to all the questions I've had. If the product lives up to expectactions (and I've bet $200 that it will!), then I have to say it's one of my best experiences as a customer so far.
Thanks Le!
Carlos Ferrao is offline   Reply With Quote
Old August 12th, 2005, 04:30 PM   #126
version 2
Hi all,
I wonder if anybody has finished this adapter yet? I have another version which is slightly different than the original one. It's round instead of square. Use basicly the same material as the square one, just slightly different design, works good. More to come.
http://www.nuocsong.com/nhatho/adapter/ver2_1.JPG
http://www.nuocsong.com/nhatho/adapter/ver2_2.JPG
http://www.nuocsong.com/nhatho/adapter/ver2_3.JPG
http://www.nuocsong.com/nhatho/adapter/ver2_4.JPG
http://www.nuocsong.com/nhatho/adapter/ver2_5.JPG
Quyen
Affordable Adapter
http://www.adapterplace.com
Old August 12th, 2005, 04:39 PM   #127
Dude
That looks really Awesome.... very nice...
Craig Bellaire
www.VerticalVideoSolutions.com
Craig Bellaire is offline   Reply With Quote
Old August 13th, 2005, 10:35 AM   #128
I just record some seconds of video using new adapter. Motor noise is there, will improve it later.
http://www.nuocsong.com/nhatho/adapter/test.mpg
Affordable Adapter
Old August 13th, 2005, 01:37 PM   #129
That comes up as an empty file for me...
Neat stuff, Quyen. You are very innovative.
Hey, I noticed you are located in Portland, my former home. Beautiful summers up there!
Bill Porter is offline   Reply With Quote
Old August 13th, 2005, 04:53 PM   #130
Sorry Bill, the link is fixed. Weather is nice here. Thanks.
Quyen
Affordable Adapter
Old August 14th, 2005, 01:05 AM   #131
Good job, looks very nice!
Old August 14th, 2005, 08:02 AM   #132
Quyen,
I must have a been a pain in the *** getting that sheet metal around the plastic, I applaud you for that - and all of the smooth edges, you really have put alot of work into this. Good job.
Old August 14th, 2005, 08:16 AM   #133
Hey Quyen,
I was looking at the pdf guide and you say that you used :
http://www.surplusshed.com/pages/item/l3385.html
But this is a rectangular and your guide shows that it is a round end to it. So is it the wrong?
Old August 14th, 2005, 10:00 AM   #134
Leo
The Surplusshed item is inside the tube so it's not visible. Thanks.
Quyen
Affordable Adapter
Old August 14th, 2005, 10:31 AM   #135
Sorry, I meant that the tube is round and the achromat is rectangular, but I guess the tube is bigger than the achromat.
