cheap vibrating GG mechanism - Page 10 at DVinfo.net
Alternative Imaging Methods
Old August 14th, 2005, 11:17 PM   #136
I downloaded firstshot.zip
I can hear the audio but no picture???
I have installed wmp10 and downloaded this 38mb file from a telephone modem so any help will take away a lot of pain. :( please
Owen Meek is offline   Reply With Quote
Old August 14th, 2005, 11:32 PM   #137
Owen,
There are 2 parts in the firstshot.zip. 1 is .mpa and 1 is .mpv. The .mpa contains only audio and .mpv contains only video. check the .mpv file in there to see if it can play in wmp10, thanks.
Quyen
Affordable Adapter
http://www.adapterplace.com
Quyen Le is offline   Reply With Quote
Old August 15th, 2005, 01:15 AM   #138
If you are totally unable to play it, let me sum it up for you. Quyen's work deserves an audience.
CAUTION - SPOILERS BELOW
Purple flowers in closeup
Focus racks back to purple flowers at medium distance; the flowers that were in closeup are now out of focus.
Focus racks back some more to more purple flowers at long distance, and some trees on the horizon. Flowers that are in foreground and medium range are now out of focus. Looks real nice!
Motor is turned off, and we can see the grain. Motor is turned back on, no grain.
Hope this helps!
Bill Porter is offline   Reply With Quote
Old August 15th, 2005, 02:12 AM   #139
funny, couldnt get that mpv playing on anything but womble mpeg video wizard. from there i rendered an output and all is good now. :)
thanks for the work Quyen Le, very nice demonstration, it was a bit like sex (u know, cause i got modem, harhar harhar har).. i dont mind the look of that grain on a v2k, gives it a bit of a dvx feel idunno, maybe you might consider your next motor attachment to have a variable speed option to get that flavour without being too static if you know what i mean. :)
Bill, i noticed that after reading your post im still learning about all this so it wasnt obvious to me from the getgo what was happeneing? now i know. :)
Old August 15th, 2005, 02:23 AM   #140
Owen,
The newer version will be available late this month or next month that has an LED, Variable switch, power plug and will be in black color. When it's available for sale, it's on our website, thanks for your advice anyway.
Quyen
Affordable Adapter
Old August 15th, 2005, 05:43 AM   #141
Owen,
You mean my post wasn't totally useless? Curses!!
The funny part is, it was intended as tongue in cheek humor and not to be helpful!
Old August 15th, 2005, 02:32 PM   #142
Hey Quyen,
I got the 1 CC syringes - but the grommets 3/16 X 5/16 X 1/16, they are too big for the syringe and slides up and down too easily. I really thought that with the better syringer, the plastic piece would be bigger too, but I guess just the outside casing.
Does the plastic holder for the white syringe part, press in tightly on the grommets and therefore on the syringe? This would make it alot easier to set the FL because it would stay in one place.
Leo Mandy is offline   Reply With Quote
Old August 15th, 2005, 03:01 PM   #143
Leo,
Mine stays really tight and won't move even if I don't apply glue. I think you got the wrong size of the grommets. What you can do is apply some glue on the plastic parts to make them thicker, then they will stay in place. After you find a proper focal plane, put some more glue to secure it, hope this helps.
Quyen
Affordable Adapter
Old August 16th, 2005, 12:33 AM   #144
Bill, will look forward to your next useless post cause i got some use out of the previous, better luck next time.. :) cheers.
Quyen Le, how much will the variable speed option cost/estimate?
Old August 16th, 2005, 01:26 AM   #145
Owen,
We are still searching for nicer looking parts. We don't know if they make nice looking potentiometers with knobs at low wattage in the range of 0-50 ohm or 0-100 ohm. We also don't know how much the parts will cost or we have to make an extra mold. I think we will have an answer for this next week, thanks for asking.
Quyen
Affordable Adapter
Old August 18th, 2005, 01:46 AM   #146
For thos who are looking for cheap parts , try:
http://www.goldmine-elec.com
They got pager motor for very cheap.
I just receive mine, (G13566 and G15241) and they are incredibly small.
out of topic: they got another hidden marvel for those interested to build
a teleprompter. Head-up display glass for 10 $. (G13586)
It is a piece of glass, coated for reflecting like a mirror on one side.
The big thing is this is not 2-way mirror (where you loose about 50% of the light). Here it is totally clear. they are cut exactly the right shape for this use.
You would pay hundreth of $ for such thing elsewhere.
nice to build a portable teleprompter with a Pocket PC or Palm gadget.
(there are some readers program like iSilo , able to scroll text on a pocket PC)
I just finished my LED lamp too, i will give you the recipe to build one very easy.
Old August 18th, 2005, 09:10 AM   #147
I am interested in the LED light thing, let me know how you did it.
also, for those interested in page motors, always check charity shops for old pages and mobile phones, usually very cheap.
Old August 18th, 2005, 09:57 AM   #148
http://www.nuocsong.com/nhatho/adapter/LED.JPG
This is a very simple design. Hope it helps.
Quyen
Affordable Adapter
Old August 18th, 2005, 10:31 AM   #149
Sorry Quyen,
I meant a full lighting rig, with the LEDs!
Old August 18th, 2005, 10:54 AM   #150
Sorry it is a bit out of topic , but here are the info.
heatsink to glue the LEDs on:
http://www.radianheatsinks.com/standard/hs1591eb.html
Leds (8 x luxeon star white 1 Watt should be enough)
http://www.ledsupply.com/led-catalo...te-luxeons.html
8 Leds are ok to grab a decent picture in a total dark room, but it is not perfect.
If you can , choose 4 white cold LED and 4 whit warm LED.
1 driver for LED (take the DC 700mA dimmable version 3021-D-E-700)
http://www.ledsupply.com/led-drivers-buckpuck.html
If you got some old LCD screen to scap, there are valuable plastic sheet and plexi glass to get from.
Epoxy glue dual-components PATTEX ALU to fix LEDs on Heatsink.
you can use the one for PC (Arctic silver, the glue not the grease ) but it is very expensive
look like this: a dual syringe with mixable resin , containing micronized aluminium
http://www.tedpella.com/14443.jpg
I think PATTEX is german stuff not distributed in USA.
Try LOCTITE Epoxy Adhesive 3805 Steel and Aluminium Epoxy Filler
Before gluing LEDs make sure the polarity of each is disposed in a way that
cabling will by short and easy.
some battery elements Li-ion 3.6V - 2 A (4 are ok)
http://www.batteryspace.com/index.a...TS&Category=739
you can find better , a kit with charger a 8 cell block (16V)
http://www.batteryspace.com/index.a...ROD&ProdID=1287
3.6 li-ion element are nice since the voltage for a led is around 3.4-3.5 Volt.
put 4 leds in serie and 2 series in parallel.
The result is a very light lamp, giving very diffuse light, you can switch on and off without risking a filament break.
People can look at it without being dazzled.
Stay cool enough to stay in the hand (but get hot anyway)
You can choose to mount the leds on a ring around the lens of your camera for MACRO.
Good luck
Giroud Francois is offline   Reply
