How much are my Redrock M2's worth?? UK at DVinfo.net
Alternative Imaging Methods
Old June 16th, 2010, 04:01 AM   #1
Hi,
looking at selling my redrock M2 (not encore) lens adapter,
I've been using it to shoot short films over the last couple of years..
It comes with
Nikon Mount
72mm Hd achromat
15mm rails (30cm long)
Sliding Manfrotto base plate
Hard mount
Flight case/Mag Box with foam cut to fit Sony Z1 whilst mounted on the rails with adapter
I've also added an external 9v battery mount to the out side of the adapter, for very quick and simple battery changes.. unlike the original design
Located in Swindon (SN5) but often travel to london, Cardiff or anywhere along M4..
I also have my back up adapter.. this again has the external 9v mod, but with a canon mount. This thing has literally been turned on for about 20mins and never used on set.. it looks brand new.. this one comes with the soft mount and I have either a 72mm or 55mm achromat that can go with this..
How much is this worth?
Andy
Andrew Trace is offline   Reply
